查看: 11382|回复: 45
[其他软件] petra安装文件,可用
  • 签到天数: 455 天
    发表于 2011-10-16 11:18:12 | 显示全部楼层 |阅读模式
    感谢blackoil提供,由于个人对这款软件不是太了解,介绍性文字来自网上
    PETRA Geological, engineering and petrophysical analysis with seismic interpretation and display tools
    Together PETRA and PetraSeis provide geoscientists an integrated application with a common data base and interface for all project and data management , well log analysis , mapping , cross-sections , seismic integration and interpretation , production and reservoir analysis , 3D visualization and Production Group Normalization Tool.
    PETRA is used for many different workflows such as:    Regional and local studies  Geologic interpretation  Mergers, acquisitions and divestitures  Well log analysis  Production & reservoir analysis  Infill drilling  Conventional & unconventional plays  Project and data management
    Typically used by:      Geologists  Production and Reservoir Engineers  Petrophycists  Geophysicists  Geoscience Technicians  Project Managers  Business Analysts
    Benefits
       To request a quote for PETRA, please complete the following:   First Name:    Last Name:    Email address:
          Try a free trial
          See videos of how PETRA is being used
       Shared, asset team tool to accomplish more in less time  Extensive tool set on the PC, with a single data base for easy, rapid reservoir or prospect definition and analysis.  Real-time integration with well , production , and log (currently Canada only) data  Fully scalable project and data management for large or small projects  Tightly integrated well , production  and seismic data for streamlined asset team workflows  Focus on data management and analysis, not just map making  Can serve as E&P platform with links to economics PowerTools® , land (ArcMap Extension), corporate data stores (middleware)
    PETRA and PetraSeis include a broad set of features and functionalities that can be utilized to answer your large and small business questions. The easy to use, easy to learn interface integrates all of this functionality with a common database enabling you to work more efficiently and productively.
      Project and data management Enerdeq DirectConnect • Commercial and Proprietary Data Sources • Shared Projects • Multi-Well • Multi-Zone • Well • Production  Tops • Logs • Tests • Cores • Perfs • Shows • Casings
      Mapping Contours w/Faults • Contour Editing • Commercial Land Grids • Import Digitized Contours • Log Curve Maps • Grid Operations • Volumetrics
      Well Log Analysis Raster to Digital • LAS and LIS • Editing • Cross Plots • Normalization • Multi-Well Analysis • Custom Calculations • Compute Reservoir Properties
      Cross Sections Structure and Stratigraphic • Digital and Raster Logs • Deviated Wells • Interactive Formation Correlation • Log Curve Editing • Depth Shifting
      Integrated Seismic with PetraSeis  2D/3D Interpretation • SEGY data loading • Synthetics • Geologic Integration • Trace Processing • Math Functions • Time/Depth Conversion • Post Stack Processing
      Production and Reservoir Analysis  Monthly Streams • Decline Curves • Cumulatives • Bubble Maps • Production Charts • Compute EUR, RR • Production Group Normalization Tool
      3D Visualization Deviated Well Tracks • PETRA Grid Surfaces • Map Images • X-Section Images • Fence Diagrams • Land Grid Overlays • Seismic  Integration
    petra.part1.rar
    6.68 MB, 阅读权限: 1, 下载次数: 1523
    petra.part2.rar
    6.68 MB, 阅读权限: 1, 下载次数: 635
    petra.part3.rar
    6.41 MB, 阅读权限: 1, 下载次数: 1676
    参与人数 1阳光币 +8 收起 理由
    hehh2009 + 8 谢谢资源共享
  • 签到天数: 640 天
    发表于 2011-10-16 11:25:52 | 显示全部楼层
    不错,BLACLOIL很给力呀
  • 签到天数: 218 天
    发表于 2011-10-16 14:13:27 | 显示全部楼层
    比较综合的软件?
  • 签到天数: 216 天
    发表于 2011-10-16 17:15:05 | 显示全部楼层
    GeoPLUS公司的Petra软件主要用于油藏描述及油藏管理,是为油气田地质研究而设计的、集项目的数据库、操作、管理、可视化和解释于一身的“GIS”类的软件,集地质、测井、物探、油藏管理各学科于一台微机上,特别符合地质研究人员的思路,非常人性智能化。
    PETRA是目前最先进的地质综合软件,在油气工业研究中集地质学、地球物理学和岩石物理数据的管理、显示和分析于一身。
    PETRA 是一个独立的有效软件包,通过提供多种高性能的功能工具模块来满足地质学家、地球物理学家、岩石物理学家和油藏工程师的需要。
    PETRA 从测井数据提取油藏属性,利用层模型计算储量,为地质研究提供了大量有效分析工具,实现了交互地层对比功能,可容易而快速地解决油藏地质研究中的关键问题。
    PETRA 代替了地质人员所必须对井资料日复一日的管理和校正工作。它继承了那些只有昂贵测井分析软件才具有的大量的测井数据管理和显示功能,提供油藏属性平面图、剖面图、交汇图、测井解释图等地质研究成果图,可加快决策速度和提高参谋质量。
    PETRA 非常适用于地质研究项目组,特别为地质勘探、钻加密井、油田扩边和提高采收率时,需要做及时、准确决策的项目组。
      Petra为用个人电脑的石油科研人员提供了独到的方法进行地质、地球物理、油藏工程数据的管理、操作、图形化、解释及综合应用。
    Petra软件是一套油田开发地质研究及油藏管理的综合软件,提供一个统一平台进行油藏描述及油藏管理,集地震解释、地质建模和油藏综合描述等多学科于一体,形成一个简单易用的应用系统,贯穿油田勘探开发始终。提供了可视化、地震解释、地质建模、储量计算、井位设计及油藏综合描述等功能。它综合运用了地质、物探、测井、试采等各种信息,在一个开放、共享的技术环境中运行,使地质家和油藏工程师们能够管理油气藏整个生产周期,贯穿油气田勘探与开发的始终。提供数据管理工具,保存和调用有关的各种生产资料,具有强大的数据交互功能,为科研人员提供了便捷、有效的分析手段。在最大程度上缩短研究周期,降低钻探风险,科学调整勘探、开发部署,减少勘探和开发成本。
    Petra 提供了独特的解决方案应用于数据的管理、处理、显示以及地质学、地球物理学、岩石物理学和工程数据的综合应用。源于实际的功能与最新用户界面技术相结合使得从原始井数据到理解油藏参数的转换变得非常容易。成果可同步应用平面图、剖面图、测井图、交汇图和用户表格等进行显示出图。
    基本特征
    1. Petra 是一个综合了地质,地球物理, 数据管理, 可视化与分析的多功能软件。 可同时满足油田勘探开发各专业人员的需要。
    2. Petra 提供的一系列功能, 用户可以简便,迅速地以交互形式来定义地质属性,从测井资料中提取油藏特性,从构造模型中做储量分析等一系列分析计算工作。
    3. Petra 为最优化开发油田提供了更好更快的决策。是需要做出及时,准确决策的项目组理想工具。
    4. Petra 代替了每月的管理与确认各种油井资料的工作。
    5. Petra 包含了一系列测井资料的管理功能,其显示、分析功能只有在一些很昂贵的工作站软件中才有。
    6. Petra 可在窗口95 或 NT 环境下运作。
    7. Petra 利用关系数据库来管理与油田开发有关的所有资料。
    数据管理
    1. Petra利用报表, 图形显示与资料表格,为用户提供了优质的工具,使得用户可以交互式更改所有数据。
    2. Petra 可以很方便地管理, 改动各种测井资料, 地层资料, 完井资料, 井斜测量,用户指定的 “z” 数值, 测井记录, 产量与历史资料。
    3. Petra引进区域概念,有效地通过地层定义来管理油藏特性。
    4. Petra 的地震数据库为输入, 输出, 操做, 显示 二 维 或三维的地震位置与特性提供了良好的基础。
    5. Petra 的项目可以包括无限的用户定义区域, 每个区域可以包括无限的以 “z” 数值, 文本或日期等形式的变量, 每个数值或日期可以标注用户说明。
    6. Petra 地质分层包括测量深度, 质量号与每个值的标注。如需要海拔值可随时计算。 地质分层可以用测量的或海海拔的TVD 值进行编辑。
    7. Petra 支持倾斜或水平井眼, 可利用表格进行方便的输入, 输出与编辑。 井斜测量可以用 ASCII 形式输入, 输出。
    8. 用户可以设定条件来选井, 进行进一步分析。
    9. 只要点击指定油井, 用户就可以以图形, 剖面或表格的形式来得到各种油井资料。
    10. 用户可以用各种其它软件生产商的格式或用户指定表格形式来输入油井与产量资料,測井资料可以用标准的LAS 和 LIS形式来输入, 输出。
    11. Petra 可以产生用户指定的格式报表,并以 ASCII 形式输出表格资料。
    12. Petra 可以向任何标准的窗口系统打印机输出图形显示或产生 WMF形式的文件来与标准软件相匹配。
    可视化
    1. Petra 图形显示有强大的功能。平面图,剖面图为用户研究油井具体资料提供了直接的桥梁。解释信息如地层相关,相关图关系,相模型可以从显示中提取并存入数据库。
    2. Petra 的显示包括底图,等值图,特性图, 剖面,交汇图,产量图,统计图与測井图预览。
    3. Petra 的底图包括每个井的资料,矿产资源线, 图例标注信息。
    4. 由任何数据库资料产生的网格化地表模型可以产生等高图, 应用鼠标点击可以产生更多的控制点。
    5. Petra 的泡泡图可以快速地显示各种变量。
    6. Petra 的特性图可以用来有效地选取符合各种条件的油井, 比如哪些油井有指定測井记录。
    7. Petra 的剖面可以完全被用户化, 包括构造与底层的深度范围, 色调, 地层顶部,油井注释, 测试信息等。
    8. 用户可以在底图上点击一系列油井来产生剖面。
    9. 剖面图是各种工作, 如地层相关, 測井资料编辑, 砂岩基线值拾取等的基础。
    信息摄取
    1. Petra可以从測井资料中提取各种油藏特性, 如孔隙度,渗透度, 碳氢含量等。
    2. Petra 的剖面显示功能为用户提供了有效的工具, 使用户能交互式地对地层顶部与測井曲线高低振幅来提取信息。
    3. Petra 从每月产量资料中计算累计产量, 平均产量, 油场范围的总体情况。
    4. 具有迅速辨别极性转换和地层测试的功能。
    5. 将处理的结果直接输入数据库, 由此综合所有处理的信息, 使之可以直接用于做图与转换。
    6. 通过对产量数据的对照将地质表面与油藏模拟相联系。
    数据转换与计算
    1. Petra 格式转换包括工业标准和用户为測井分析及标准化而定义的方程。
    2. Petra 用区块边界定义来计算一个或多个区块的地层厚度。厚度可以包含井口方向校正,甚至构造倾斜与角度,从而提供了更为真实的层序厚度。
    3. Petra 提供用户定义的方程来计算区域深度转换。
    4. Petra 可以产生油井, 地震, 或人工输入的“z”资料的网格表面模型, 同时可以加入用户通过手描或数子化的解释。
    5. Petra 可以从覆盖一个或多个多边形区域的网格模型中产生储量报告。
    6. Petra 为用户选取的一个或多个油井进行所有的计算, 或为覆盖用户选用的一个或多个区域的整个数据库同时进行计算。
    参与人数 1阳光币 +3 收起 理由
    justbetoo + 3
  • 签到天数: 44 天
    发表于 2011-10-17 00:03:26 | 显示全部楼层
    真的可以用么?下了试试看
  • 签到天数: 104 天
    发表于 2011-10-19 08:02:51 | 显示全部楼层
    是使用,还是完全
  • 签到天数: 104 天
    发表于 2011-10-22 08:14:00 | 显示全部楼层
    ok,very good
  • 签到天数: 312 天
    发表于 2011-10-28 11:31:19 | 显示全部楼层
    什么软件了,没有用过
    pennyye63 该用户已被删除
    发表于 2011-11-11 10:43:53 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
  • 签到天数: 312 天
    发表于 2011-12-23 08:28:51 | 显示全部楼层
    既然这么好的软件,怎么反响怎么冷淡啊!
    GMT+8, 2025-4-25 10:34 , Processed in 0.064416 second(s), 30 queries .
