查看: 2014|回复: 4
第一届世界稠油大会Technical Paper 7 Field Facilities共有13篇论文
  • 签到天数: 36 天
    发表于 2011-10-7 10:59:07 | 显示全部楼层 |阅读模式
    第一届世界稠油大会Technical Paper这里共有13篇论文
    An Update on Joslyn lease:
    First SAGD Facility
    Using Evaporators, Drum Boilers,
    And Zero Liquid Discharge Crystallizers
    To Treat Produced Water
    P. PEDENAUD, R KEHOE
    TOTAL
    P VALERO, B. BURG
    TOTAL E&P Canada Ltd.
    Abstract
    Steam Assisted Gravity Drainage (SAGD) is a technique of
    heavy oil recovery used on oil sands in Alberta, Canada. Steam
    is injected down hole in the reservoir and the steam fluidizes the
    heavy oil and allows the oil/water mixture (emulsion) to be
    brought to the surface. The oil is recovered as product and the
    produced water is de-oiled and treated for reuse in steam
    generation. To treat de-oiled produced water, surface facilities
    use traditionally a combination of warm or hot lime softening
    (WLS), filtration, and weak acid cation (WAC) ion exchange.
    The pre-treated water is recycled and sent to ``Once Through
    Steam Generators`` (OTSG) which produce an 80% quality
    steam. The steam-water mixture is sent through a series of
    separators to produce the 100% quality steam required for
    injection into the oil well.
    Field Facilities 13.rar
    2.83 MB, 下载次数: 19
    售价: 5 阳光币  [记录]
    参与人数 1阳光币 +15 收起 理由
    justbetoo + 15
  • 签到天数: 242 天
    发表于 2011-10-7 12:22:52 | 显示全部楼层
    支持~~谢谢LZ的资料
    发表于 2011-10-12 10:46:30 | 显示全部楼层
    回复 1# fortune860101
    学学
  • 签到天数: 368 天
    发表于 2012-3-14 12:46:16 | 显示全部楼层
  • 签到天数: 2525 天
    发表于 2014-7-12 19:15:56 | 显示全部楼层
    GMT+8, 2025-2-23 07:07 , Processed in 0.387505 second(s), 30 queries .
