查看: 1747|回复: 3
第一届世界稠油大会1 Thermal Recovery Optimization 共有26篇论文
  • 签到天数: 36 天
    发表于 2011-10-4 05:27:09 | 显示全部楼层 |阅读模式
    第一届世界稠油大会Technical Paper
    Analysis of the Solution Gas Effect on SAGD
    Slope Drainage Rate
    NEIL EDMUNDS
    Laricina Energy Ltd.
    This paper has been selected for presentation and publication in the Proceedings at the 1st Heavy Oil Conference.
    All papers selected will become the property of WHOC. The right to publish is retained by the WHOC’s Publications Committee.
    The authors agree to assign the right to publish the above-titled paper to WHOC, who have conveyed non-exclusive right to the
    Petroleum Society to publish, if it is selected.
    Abstract
    Non-condensible gases tend to accumulate at a steam
    (condensation) front, and act as an insulating blanket on the
    SAGD convection mechanism. This can have a material impact
    on the drainage rate, for example as calculated by Butler's
    equation for SAGD rate.
    The effect of varying amounts of liberated solution methane
    on a SAGD front is approached by calculating the temperature
    drop that would be due to a given blanket thickness, and thus
    deriving a correction factor to the normal (Butler) rate. In
    addition to the usual petrophysical parameters, the corrected
    rate is also a function of the reservoir GOR and the SAGD
    operating pressures.
    Results indicate that small amounts of accumulated
    methane can reduce drainage rates by factors of up to 2 or
    more. The required amounts are small fractions of the normal,
    initial solution gas/oil ratio in the McMurray formation; it is
    therefore concluded that further understanding of SAGD
    chamber methane content, accumulation, and removal is
    essential to confident reservoir forecasting and optimization.
    这里共有26篇论文
    Thermal Recovery Optimization 26.part1.rar
    4.77 MB, 下载次数: 23
    售价: 5 阳光币  [记录]
    Thermal Recovery Optimization 26.part2.rar
    4.77 MB, 下载次数: 22
    Thermal Recovery Optimization 26.part3.rar
    4.53 MB, 下载次数: 23
    参与人数 1阳光币 +15 收起 理由
    justbetoo + 15
  • 签到天数: 455 天
    发表于 2011-10-4 08:55:37 | 显示全部楼层
    这个应该听听啊
  • 签到天数: 368 天
    发表于 2012-3-14 12:34:09 | 显示全部楼层
  • 签到天数: 2179 天
    发表于 2012-4-27 17:16:20 | 显示全部楼层
    这个跟我的设计还是有点出入的
    GMT+8, 2025-7-9 18:04 , Processed in 0.074725 second(s), 28 queries .
