查看: 1366|回复: 2
A novel viscoelastic system from a cationic surfactant
  • 签到天数: 71 天
    发表于 2011-9-23 10:35:19 | 显示全部楼层 |阅读模式
    novel system is compared with the published one of 3-hydroxy-2-naphthoic acid (3,2-HNC) mixed with CTAOH. We investigated the phase
    behavior and properties of the phases in aqueous solutions of 100 mM CTAOH with 2,1-HNC. In both systems a multilamellar vesicle phase
    is formed when the naphthoate/surfactant ratio (r) reaches unity. When an increasing amount of 2,1-HNC is mixed with a micellar solution
    of 100 mM CTAOH, an isotropic low-viscous micellar solution, a viscoelastic gel (consisting of rodlike micelles), a turbid region (two-phase
    region), and a viscoelastic liquid crystalline gel (consisting of multilamellar vesicles, MLV) were formed. The vesicular phase is highly
    viscoelastic and has a yield stress value. The transition from the micellar to the vesicle phase occurs for CTAOH/2,1-HNC over a two-phase
    region, where micelles and vesicles coexist. Also it was noticed that 2,1-HNC is dissolved in 100 mM CTAOH until the naphthoate/surfactant
    ratio reaches ∼ 1.5, and the liquid crystalline phases were found to change their color systematically when they were viewed between two
    crossed polarizers. The vesicles have been characterized by differential interference contrast microscopy, freeze-fracture electron microscopy,
    and cryo-electron microscopy (cryo-TEM). The vesicles were polydisperse and their diameter ranged from 100 to 1000 nm. The interlamellar
    spacing between the bilayers was determined with small angle neutron scattering and agrees with the results from different microscopical
    methods. The complex viscosity rises by six orders of magnitude when rodlike micelles are formed. The complex viscosity decreases again in
    the turbid region, and then rises approximately six orders of magnitude above the water viscosity. This second rising is due to the formation
    of the liquid crystalline MLV phase.
    A novel viscoelastic system from a cationic surfactant and a hydrophobic counterion.pdf
    3.88 MB, 下载次数: 7
  • 签到天数: 640 天
    发表于 2011-9-23 10:55:35 | 显示全部楼层
    大家都看不懂英语
  • 签到天数: 2525 天
    发表于 2014-7-12 19:00:48 | 显示全部楼层
    GMT+8, 2025-5-13 09:23 , Processed in 0.054882 second(s), 25 queries .
