查看: 2542|回复: 3
[ECLIPSE] 关键字EQLDIMS
  • 签到天数: 144 天
    发表于 2011-9-5 10:16:17 | 显示全部楼层 |阅读模式
    请教大家,在eclipse数据文件中RUNSPEC里EQLDIMS有5个数字分别代表什么?
  • 签到天数: 640 天
    发表于 2011-9-5 10:40:54 | 显示全部楼层
    The data consists of up to five items, specifying the dimensions of the equilibration
    tables. The data must be terminated by a slash (/).
    1 NTEQUL, the number of equilibration regions entered using EQLNUM in the
    REGIONS section. Different equilibration regions may be used to initialize
    different parts of the reservoir that are not in mutual hydrostatic equilibrium. (See
    keywords EQLNUM in the REGIONS section and EQUIL in the SOLUTION section.)
    DEFAULT: 1
    2 The number of depth nodes in any table of pressure versus depth constructed
    internally by the equilibration algorithm.
    ECLIPSE 100 DEFAULT: 100
    ECLIPSE 300 DEFAULT: 50
    3 The maximum number of depth nodes in any RSVD, RVVD, RSWVD, RTEMPVD,
    PBVD or PDVD table entered in the SOLUTION section to define the initial Rs, Rv,
    Tr, Pb or Pd versus depth.
    ECLIPSE 300 For ECLIPSE 300 this parameter is also applied to the number of entries in the
    ZMFVD keyword.
    ECLIPSE 100  DEFAULT: 20
    4 The maximum number of tables of initial tracer concentration versus depth
    (keyword TVDP in the SOLUTION section).
    DEFAULT: 1
    5 The maximum number of depth nodes in any table of initial tracer concentration
    versus depth (keyword TVDP in the SOLUTION section).
    看看ECLIPSE自带的帮助文件就明白了
    平时建模的时候一般不会自己设置这个关键字
  • 签到天数: 144 天
     楼主| 发表于 2011-9-5 10:54:47 | 显示全部楼层
    回复 2# badboy0504
        您能帮我解释一下吗?通俗点的
  • 签到天数: 137 天
    发表于 2011-10-2 23:54:40 | 显示全部楼层
    1.平衡区域个数
    2.深度vs压力表格中节点的个数
    3.(Rs,Rv,Tr, Pb , Pd)等vs深度数据表中的深度最大节点数
    4.原始示踪剂浓度vs深度的表格数
    5.原始示踪剂浓度vs深度表格中的最大节点数
    参与人数 1阳光币 +2 收起 理由
    ych89743244a + 2
    GMT+8, 2025-5-12 22:28 , Processed in 0.055378 second(s), 27 queries .
