查看: 3910|回复: 6
[ECLIPSE] eclipse中NSTACK到底是什么意思?
  • 签到天数: 16 天
    发表于 2011-9-2 16:04:53 | 显示全部楼层 |阅读模式
    到底应该设置成多大,为什么有的模型设置的很小?甚至是负的,求教!
    The data represents the size of the stack of previous search directions held by the ORTHOMIN linear solver
  • 签到天数: 68 天
    发表于 2011-9-3 00:47:21 | 显示全部楼层
    牵扯到算法 number of stack吧
  • 签到天数: 157 天
    发表于 2011-9-29 09:11:41 | 显示全部楼层
    不同的值表示迭代方向,正负都有,Eclipse里有说明
  • 签到天数: 158 天
    发表于 2011-10-5 13:38:53 | 显示全部楼层
    NSTACK
    Linear solver stack size
    The data represents the size of the stack of previous search directions held by the ORTHOMIN linear solver (see "Solution of the Linear Equations" on page 821 of the "ECLIPSE Technical Description"). This may be increased if the linear solver shows convergence problems. A good value for many ECLIPSE 100 problems is 10, while many compositional ECLIPSE 300 problems often require 40. Difficult problems may require a larger value. ECLIPSE prints a message advising increased NSTACK if this will increase computing efficiency. Increasing the value of NSTACK increases the memory required for a run.
    ORTHOMIN linear solver 正交极小化算法线性求解。
    convergence problems 收敛问题
    ECLIPSE 100 problems 一般设置为10  组分模型ECLIPSE 300 problems 一般设置为40 复杂的问题需要设置的值越大
    值越大运行需要的内存越大
  • 签到天数: 73 天
    发表于 2012-10-13 22:07:53 | 显示全部楼层
    Stack Size of Previous search directions (NSTACK)
  • 签到天数: 42 天
    发表于 2012-10-24 21:45:57 | 显示全部楼层
  • 签到天数: 15 天
    发表于 2016-1-18 14:06:54 | 显示全部楼层
    非常好的,学习了,然而还是不知道怎么办
    GMT+8, 2025-5-12 18:07 , Processed in 0.068433 second(s), 23 queries .
