查看: 1347|回复: 0
三相渗透率曲线出现问题,如何解决?急求高人相助?
  • 签到天数: 29 天
    发表于 2011-3-25 10:41:37 | 显示全部楼层 |阅读模式
    <warning date="1/1/1983" time="0.00000000000000">
    SWOF/SGOF table 1 have different Kro and Krg values
    of 1.00000 and .395540 at Somax=1-Swco-Sgco
    This can cause discontinuities as when a fluid changes
    from a gas to an oil (or vice versa) as a single phase.
    If gas injection is to be used it is recommended that these
    are set the same or the HCSCAL option is used in
    the FORMOPTS keyword
    THIS TABLE IS INTERNALLY CONSTRUCTED
    AND WILL NOT BE FOUND IN THE DATA DECK
    GMT+8, 2025-5-12 23:06 , Processed in 0.080938 second(s), 23 queries .
