TA的每日心情 | 慵懒 2020-4-24 17:38 |
签到天数: 29 天 [LV.4]偶尔看看III
请问:在模拟时遇见这个问题
Initializing...
Saving : 110_COM.GRID
@--Message at time 1 January 1983 step 0:
@ Explicit initialisation of Water saturation(SWAT).
@ Explicit initialisation of Gas saturation(SGAS).
@ Explicit initialisation of molar fractions (ZMF).
@ Explicit initialisation of pressure.
Memory for streamlines, allocated: 0.7MB Usage: 0.000
Using E300 for Saturation Calculations
Memory usage after initialization of the model
Memory Heap(MB) : Current Usage 45.0 Peak Usage 67.3
Memory usage pr active cell(KB) : 22.1
Total Available Disk Space On Drive e (MB) : 53082.2
Saving : 110_COM.INIT
1------------------------------------------------------------------------------------------------------------------------------ 1
CHARACTERISTICS Basic Simulation Characteristics 0.0000 Days report step 0, 1 Jan 1983
Numerical Method : STANDARD
Dimension : 3D
Segregation : ON ( 1 Iteration(s))
Compressibility : YES
Tensor : DIAGONAL
Equation Solver : ALGEBRAIC MULTI GRID SOLVER
Local Grids : NO
Saturation Tables : 1
PVT Tables : 1
Rock Tables : 1
Dual Porosity : NO
Number of Wells : 1
Number of Connections: 5
Simulation start : 01 January 1983
# Report Steps : 12
Number Of Processors : 4
GridName Id Level Cells Active
GLOBAL 0 0 3125 3125
Total: 3125 3125
Number of contacts:
Left: 3000
Back: 3000
Up: 2500
PV 2.00000e+005(RM3) at reference pressure
PV 1.97281e+005(RM3) RC 0.00(%) PAV 1.2800e+002 (BAR)
WIP 1.34843e+005(SM3) CWF 0.00000e+000(SM3) WIIP 1.34843e+005(SM3) MW 0.00(%)
OIP 0.00000e+000(SM3) COF 0.00000e+000(SM3) OIIP 0.00000e+000(SM3) MO 0.00(%)
GIP 5.91843e+004(SM3) CGF 0.00000e+000(SM3) GIIP 5.91843e+004(SM3) MG 0.00(%)
1IP 5.95124e+004(KG) CCF 0.00000e+000(KG) CIIP 5.95124e+004(KG) MC 0.00(%)
2IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
3IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
4IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
5IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
6IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
7IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
8IP 0.00000e+000(KG) CCF 0.00000e+000(KG) CIIP 0.00000e+000(KG) MC 0.00(%)
CPU Initialization : 0.8
No errors found in this data set.
FrontSim License Check....
Black Oil : Jan 1 0
Compositional : Jan 1 0
1------------------------------------------------------------------------------------------------------------------------------ 2
REPORT Summary of report step 31.4167 Days report step 1, 1 Feb 1983
Report 1 Time 0.00 --> 31.42 (01 Feb 1983) StopTime: 365.00
Step 1 Time 0.00 --> 15.71 Reason: HalfRep
Pressure : 4 8.9e-006 1 3.5e-004
Pressure : 1 2.5e-006 2 6.9e-008
Saturation : Generated 0 starting points (SLN density 0.000000).
Delta-P after the saturation solver max: 15.677%, rms: 15.442%
CPU Pressure : Asm 0.0 Sol 0.0 Vt 0.0 Tot 0.0
CPU Saturation : StGen 0.0 StSolve 0.0 StGrav 0.3 Tot 0.7
CPU Cumulative : Asm 0.0 Sol 0.0 Vt 0.0 Sat 0.7 Tot 1.5
Memory Heap(MB) : Current Usage 48.7 Peak Usage 67.3
Step 2 Time 15.71 --> 31.42 Reason: Report
Pressure : 2 5.8e-006 1 2.2e-005
Delta-P after the saturation solver max: 0.081%, rms: 0.073%
@--Warning at time 16 January 1983 step 2:
@ Not able to access sln file - file probably corrupt/noexisting
CPU Saturation : StGen 0.0 StSolve 0.0 StGrav 0.3 Tot 0.6
CPU Cumulative : Asm 0.0 Sol 0.0 Vt 0.0 Sat 1.3 Tot 2.1
Memory Heap(MB) : Current Usage 48.8 Peak Usage 67.3
Saving : 110_COM.S0001
PV 1.97266e+005(RM3) RC 0.00(%) PAV 1.0809e+002 (BAR)
WIP 1.87975e+005(SM3) CWF 0.00000e+000(SM3) WIIP 1.34843e+005(SM3) MW -27.21(%)
OIP 4.69555e-013(SM3) COF 0.00000e+000(SM3) OIIP 0.00000e+000(SM3) MO 0.00(%)
GIP 4.58321e+003(SM3) CGF 0.00000e+000(SM3) GIIP 5.91843e+004(SM3) MG 0.00(%)
1IP 1.79387e+004(KG) CCF 0.00000e+000(KG) CIIP 5.95124e+004(KG) MC 231.75(%)
@ Simulation stopped due to high material balance error
Oil Production : 0.00000e+000 SM3
CPU Time : 0 H 0 M 2.47 S
FrontSim 2008.1 Apr 26 2008
该如何解决啊?如何检查物质平衡呢?请高手指点一下,不胜感激! |
