用户名  找回密码
查看: 1346|回复: 0
Toward the Formalization of Sequence Stratigraphy
  • 签到天数: 706 天
    发表于 2010-12-4 00:30:18 | 显示全部楼层 |阅读模式
    fomalization of sequence stratigraphy.pdf (1.08 MB, 下载次数: 10, 售价: 1 阳光币)
    By: IWGSS (Octavian Catumeanu, the author of Principles of sequence stratigraphy, 2006)
    Abstract
    Sequence stratigraphy is a modern and hugely popular approach of integrated stratigraphic
    analysis, and yet it is the only type of stratigraphy that is not standardized in international
    stratigraphic codes. This paradox is explained by the existence of several competing models, and
    by the dissemination of confusing or even conflicting terminology. The key to the formal
    inclusion of sequence stratigraphy within the array of stratigraphic disciplines is the recognition
    of what are core aspects versus those of lesser significance, and an appreciation that the approach
    to standardization has to be entirely unbiased. With at least five different sequence stratigraphic
    models currently in use, the main task is to find what they have in common, and formalize those
    core aspects that everybody can accept, recognizing what is trivial and may be left to the
    discretion of the practicing geologist.
    It is well-established that all sequence stratigraphic models have merits and pitfalls, and that
    success in their application may vary with the case study; otherwise, a single universal model
    would have emerged by now. The approach to standardization proposed here is to promote those
    concepts that can be accepted by all, and thus retain flexibility in the application of the sequence
    stratigraphic method. This approach is in line with the way allostratigraphy is standardized in the
    North American Stratigraphic Code and in the International Stratigraphic Guide. After including
    the discontinuity/unconformity-bounded units of allostratigraphy in the Code and Guide,
    formalizing the concept of ‘sequence’ as a unit bounded by unconformities or their correlative
    conformities is the next logical step, long overdue. Once the ‘sequence’ is formalized as a
    generic concept, one can take a step further and list the various types of sequences, by defining
    what surfaces are selected as sequence boundaries in each case. Because no one model may
    provide the optimum approach for all circumstances, trying to define what specific surfaces of
    sequence stratigraphy should receive the formal status of ‘sequence boundary’ is not practical,
    and will never provide an acceptable solution for all groups. Furthermore, depending on location
    within the basin, each sequence stratigraphic surface may be ‘practical’ (i.e., easy to map) in
    some depositional systems and ‘impractical’ (i.e., difficult to map) in others. Similarly, the
    mappability of various sequence stratigraphic surfaces also depends on the type of data (e.g.,
    outcrop vs. well-log vs. seismic) available for analysis. This paper strives to identify the common
    ground between the various sequence stratigraphic ‘schools’, and assesses what is reasonable to
    standardize at this point in international stratigraphic codes or guides.
    GMT+8, 2025-4-12 23:01 , Processed in 0.096733 second(s), 23 queries .
