查看: 4569|回复: 4
landmark的Oracle OWSYSSID问题求教!!
  • 签到天数: 17 天
    发表于 2009-10-11 16:11:29 | 显示全部楼层 |阅读模式
    图片:
    Project Admin 有个错误提示:
    Error Opening OWSYS
    The master database owsys could not be connected.
    Check to see that the value of OWSYSSID is set correctly.
    Make sure that connection to OWSYSSID can be made.
    Make sure that both ORACLE and listener are running.
    RUN orastat for more diagnosic information.
    See the OpenWorks System Administraion Guide for details
    orastat  信息如下:
    liu6{ow03}% orastat
    # Checking environmentals on host: liu6...
    OWHOME is set to:              /home2/OpenWorks
    ORACLE_HOME is set to:         /home2/oracle/OraHome1
    ORACLE_SID is set to:          owwsy
    OWSYSSID is set to:            owwsy
    # Determining Landmark applications installed ...
    GeoDataLoad: GeoDataLoad        2003.12.0.1     UPDATE PASSED 12102005@10:22:48 /home2/OpenWorks/GeoDataLoa
    d Linux
    SeisWorks: SeisWorks    2003.12.1       INSTALL PASSED 10102005@15:29:03 /home2/OpenWorks/SeisWorks Linux
    SeisUtils: SeisUtils    2003.12.1       INSTALL PASSED 10102005@15:30:37 /home2/OpenWorks/SeisUtils Linux
    StratWorks: StratWorks  2003.12.0.1     INSTALL PASSED 10102005@15:40:18 /home2/OpenWorks/StratWorks Linux
    StratUtil: StratUtil    2003.12.0.1     INSTALL PASSED 10102005@15:39:52 /home2/OpenWorks/StratUtil Linux
    PetroWorks: PetroWorks  2003.12.0.0     INSTALL PASSED 10102005@15:45:26 /home2/OpenWorks/PetroWorks Linux
    SynTool: SynTool        2003.12 INSTALL PASSED 10102005@16:13:33 /home2/OpenWorks/SynTool Linux
    # Checking background daemons ...
    Dynamic PD is ENABLED
    NetD is operational on host localhost for Dynamic PD
    Dynamic PD Session is RUNNING: SessionID: OPENWORKS_600_ow03@192.0.2.88:0_PD Value: liu6:27962
    Dynamic Pointing Dispatcher operational. checkpd returns OK
    root      6418     1  0 15:18 ?        00:00:00 /home2/OpenWorks/lam/bin/lmgrd -c /home2/OpenWorks/lam/lice
    nse.dat
    root      6435  6418  0 15:18 ?        00:00:00 licsrv -T liu6 7.2 3 -c /home2/OpenWorks/lam/license.dat --
    lmgrd_start 4ad186e3
    LAM SERVER (lmgrd) running OK
    licsrv server running OK
    # ORACLE sids/host accessable through listener are ...
    Found /home2/oracle/OraHome1/network/admin/tnsnames.ora
    INST1_HTTP  liu6
    OWWSY  liu6
    *** Cannot rsh to liu6 as ow03
    *** Unable to check ORACLE daemons
    NetD server running OK on liu6 for Project Management purposes
    checkRSvD returns OK for liu6 for Project Management purposes
    # Checking ORACLE daemons on liu6...
    oracle    6539     1  0 15:19 ?        00:00:00 ora_pmon_owwsy
    pmon running OK on liu6
    oracle    6541     1  0 15:19 ?        00:00:00 ora_dbw0_owwsy
    dbw0 running OK on liu6
    oracle    6543     1  0 15:19 ?        00:00:00 ora_lgwr_owwsy
    lgwr running OK on liu6
    oracle    6547     1  0 15:19 ?        00:00:00 ora_smon_owwsy
    smon running OK on liu6
    oracle    6549     1  0 15:19 ?        00:00:00 ora_reco_owwsy
    reco running OK on liu6
    tnslsnr running OK on liu6
    # Checking sqlplus/sql*net as ow03...
    ERROR:
    *** WARNING: Database cannot be accessed by ow03 ***
    *** Make sure that ow03 is an External ORACLE User
    发表于 2010-12-28 16:50:03 | 显示全部楼层
    tnslsnr没有起来(要用dba的用户起),或是数据库根本没有起来
    发表于 2010-12-28 16:50:36 | 显示全部楼层
    兄弟现在搞定了没有
  • 签到天数: 64 天
    发表于 2011-9-12 11:18:34 | 显示全部楼层
    oracle没起来吧
    lsnrctl -status看看
  • 签到天数: 5 天
    发表于 2012-10-23 18:43:00 | 显示全部楼层
    我的也是这个问题,请教下,能不能详细的说明下
    GMT+8, 2025-5-16 01:59 , Processed in 0.051846 second(s), 23 queries .
