查看: 719|回复: 0
Petrel2018 工区文件加载失败 可否有解决方法
发表于 2023-5-24 00:33:38 | 显示全部楼层 |阅读模式
错误提示:Load error: Illegal to wait on a task in a Windows Runtime STA
petrel可以正常打开,一旦选择打开工区文件就会报错
Message中的信息如下【Warning: The project character set '1252  (ANSI - 拉丁语 I)' is different than the current system character set '936   (ANSI/OEM - 简体中文 GBK)'.
The current operating system display language may need to be changed to display text correctly (see Microsoft documentation, 'Language for non-Unicode programs').
ZGY Cloud plug-in is disabled.
CommonApplicationData path = [ C:\ProgramData\Schlumberger\Petrel\2018 ]
Using HDF5 version 1.8.19
Ribbon configuration is loaded.
Error opening reference project D:\Program Files\Schlumberger\Petrel 2018\Extensions\Schlumberger\Kinetix Shale\Petrel_workflows.petR】
错误提示如图
错误提示如图
GMT+8, 2025-7-22 01:15 , Processed in 0.059043 second(s), 27 queries .
