查看: 660|回复: 2
[ECLIPSE] eclipse组分模型的问题,求老师们指点
  • 签到天数: 52 天
    发表于 2020-10-15 17:16:00 | 显示全部楼层 |阅读模式
    请问各位老师,我用eclipse组分模型跑水驱的时候,出现了如下错误,请问该怎么解决的?这个模型之前黑油可以跑通,但是用组分跑就出现如下错误,是有要求需要我用组分跑,希望大家给点建议
    1.AN UNSUPPORTED ERROR HAS OCCURRED. PLEASE CONTACT SCHLUMBERGER FOR ASSISTANCE REPORTING THE ERROR MESSAGE: MAXIMUM RECURSION DEPTH EXCEEDED IN CMP
    2.MAXIMUM RECURSION DEPTH EXCEEDED IN CMP
    3. PLEASE CHECK FOR FILES WITH EXTENSION .ECLRUN_DBG BOTH LOCALLY AND ON THE SERVER. THIS WILL ASSIST IN SOLVING YOUR PROBLEM
    发表于 2021-10-15 10:34:38 | 显示全部楼层
    @           UNRECOGNISED KEYWORD EOS  --?IN PROPERTY DATABug An unsupported error has occurred. Please contact Schlumberger for assistance reporting the error message: [Errno 0] Error Bug [Errno 0] Error Bug Please check for files with extension .eclrun_dbg both locally and on the server. This will assist in solving your problem
    发表于 2021-10-15 10:35:53 | 显示全部楼层
    你好,我也遇到了同样的问题,请问您解决了吗,可以帮忙解答一下吗? @           UNRECOGNISED KEYWORD EOS  --?IN PROPERTY DATABug An unsupported error has occurred. Please contact Schlumberger for assistance reporting the error message: [Errno 0] Error Bug [Errno 0] Error Bug Please check for files with extension .eclrun_dbg both locally and on the server. This will assist in solving your problem
    GMT+8, 2025-5-15 14:15 , Processed in 0.054464 second(s), 20 queries .
