查看: 2892|回复: 2
Surfer 19.1.189 最新版-仅安装文件
  • 签到天数: 243 天
    发表于 2020-9-9 21:58:51 | 显示全部楼层 |阅读模式
    官方 8月31日, 2020更新
    下载地址:
    http:双杠downloads.goldensoftware.com/programs/surfer18/Surfer_18_Installer.exe(改哪里,聪明的你不用我说)
    改善如下:
    • 3D View: 3D PDF Export
    • 3D View: Enable Undo
    • Attribute Table: copy/paste the headers with rows
    • Attribute Table: import attributes from file (Join)
    • Attribute table: Sort by attribute value by clicking column header
    • Attribute Table: update the color of selected cells/rows
    • Base map: select only objects in base layer when in edit mode
    • Convert grid-based layer types
    • Coordinate System: Add CRTM05 (Costa Rica, EPSG 5367)
    • Coordinate System: Add Palestine 1923 Palestine Belt and Palestine Grid (EPSG 28191, 28192)
    • Coordinate System: add the FIPS code to each SPCS zone
    • Copy/Paste Format: include Classed Post Map class mins/maxs
    • Drag and Drop files into Surfer window to open as map
    • EMF Export: rotated text is exported as polygons and polylines when exporting in map units (but not paper space) or paste as EMF
    • File | Open: open files as a map instead of opening in Grid Editor or the Worksheet
    • Grid operations: make "Add grid as layer to" checkbox persistent
    • Make contouring faster with large grids
    • New Base Symbology: Charts: Pie map
    • Open more than one file at a time with File | Open (SRF, DAT, GRD)
    • Post Map and Classed Post Map: add Data Exclusion Filter
    • Post Map, Classed Post Map and Base from Data: Edit Data option to open data in the workshseet
    • Save As dialog: remove extension from autofilled file names
    • Share grids/files in background so don't have to load multiple times
    • SRF Thumbnail Previews
    • Undo: Previous View (Zoom Previous)
    • Update map Scale and Scale Bar when drag selection handles to resize map
    修正:
    • 3D View: 3D points: does not update when add new points
    • 3D View: Axis Labels: add Thousands separator decreases font size
    • 3D View: copied/pasted/moved point still uses XY location of original point
    • 3D View: Lat/long point data layers disappear when reprojected to linear
    • 3D View: point Density limiting points incorrectly
    • 3D View: post map symbols do not appear in 3D when there's only one point
    • 3D View: Z Axis scaling is not updated when point Density is changed (Z axis goes to infinity)
    • Automation: GridData3 is not sending parameters for grid size and blanking
    • Base Symbology: Un/Classed Symbols and Unclassed Colors: colormap uses 0-1 for data min/max instead of attribute range when there's no variation in the data
    • Contour maps are limited to grids no larger than 65535 nodes on a side (incorrect fill)
    • Crash after selecting JPG in the Select Format dialog
    • Crash when duplicate a contour layer
    • Crash when pasting multiple cells from worksheet to Attribute Table
    • Defaults: Post Map pFont properties aren't applied
    • Defaults: Post Map pLabCol does not set label column
    • Defaults: Post Map pPosType doesn't work
    • Double click on BAS opens empty Scripter
    • Drop Shadow: positive and negative offsets are applied in the same direction
    • GridTIFF import: XY ranges are shifted slightly
    • Incorrect contours near blanked saddle points
    • Internal Error when gridding with Local Polynomial with No Search (localpolynomialgridder.cpp)
    • Internal error when opening the math text editor (mtxmetrics.cpp)
    • Internal Error when using Grid Calculus (calculus.cpp)
    • KML import: embedded image isn't imported in the correct location
    • Options: Post map labels don't use default Font properties
    • Post Map: colormap data limits change when replacing data file
    • Print Preview is wrong when Print method is set to View
    • Set Limits: Limits reverted to default if you click in Properties and then apply the limits and change the scale.
    • SRTM WCS server is downloading grids with Z range of 0 to 1
  • 签到天数: 2319 天
    发表于 2020-9-10 14:59:49 | 显示全部楼层
  • 签到天数: 243 天
     楼主| 发表于 2020-9-10 20:04:57 | 显示全部楼层
    初次发贴,多谢捧场!
    GMT+8, 2025-5-15 17:43 , Processed in 0.052811 second(s), 19 queries .
