查看: 557|回复: 0
[ECLIPSE] 哪位好心人帮忙看看eclipse2013安装失败怎么解决
  • 签到天数: 133 天
    发表于 2020-7-8 08:57:52 | 显示全部楼层 |阅读模式
    Error #1 Please click on "Open flex log" view problem########################################################
    (上午 8:49:31)  The version of lmgrd.exe is 11.11.0.0 build 106800 The modified date is 2012/8/23 星期四 下午 4:13:12
    (上午 8:49:31)  The version of slbsls.exe is 3, 0, 0, 0 The modified date is 2012/11/19 星期一 上午 11:09:42
    (上午 8:49:31)  The version of SLBLicensing.exe is 2013.01.0.0 The modified date is 2013/3/8 星期五 上午 11:06:08
    (上午 8:49:31)  The following operating system is installed  Microsoft Windows 7 旗舰版  Service Pack 1
    Network cards found on localhost
    Intel(R) Ethernet Connection (2) I219-LM 309C2352CCDA fe80::fc3c:2755:93d5:9809%11 10.207.53.28
    All the environment variables on user's machine used by flex and our products
    (上午 8:49:31)  The LM_LICENSE_FILE system environment variable is not set
    (上午 8:49:31)  The LM_LICENSE_FILE user environment variable is not set
    (上午 8:49:31)  The SLBSLS_LICENSE_FILE system environment variable is not set
    (上午 8:49:31)  The SLBSLS_LICENSE_FILE user environment variable is set to = @localhost;
    (上午 8:49:31)  The SLBFD_LICENSE_FILE system environment variable is not set
    (上午 8:49:31)  The SLBFD_LICENSE_FILE user environment variable is not set
    (上午 8:49:31)  The LMGRD.SLB_LICENSE_FILE system environment variable is not set
    (上午 8:49:31)  The LMGRD.SLB_LICENSE_FILE user environment variable is not set
    Registry setting under the following key HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\FLEXlm License Manager
    GMT+8, 2025-5-13 10:17 , Processed in 0.088895 second(s), 20 queries .
