查看: 406|回复: 0
[ECLIPSE] 求助ECLIPSE模型无法运行
  • 签到天数: 18 天
    发表于 2020-5-14 14:13:35 | 显示全部楼层 |阅读模式
    Bug An unsupported error has occurred. Please contact Schlumberger for assistance reporting the error message: 'ascii' codec can't encode characters in position 9-11: ordinal not in range(128)
    Bug 'ascii' codec can't encode characters in position 9-11: ordinal not in range(128)
    Bug Please check for files with extension .eclrun_dbg both locally and on the server. This will assist in solving your problem
    Exception AttributeError: "History instance has no attribute '_mutex'" in <bound method History.__del__ of <__main__.History instance at 0x02B9B378>> ignored
    一运行就提示这个,ecl自带的算例都跑不了。。。谁知道是怎么个情况啊
    GMT+8, 2026-7-20 18:01 , Processed in 0.047875 second(s), 21 queries .
