查看: 5206|回复: 8
怎么在geoframe里面加相干体数据(sey的)
    发表于 2009-9-20 14:51:24 | 显示全部楼层 |阅读模式
    我在别的软件里面做了相干体,导出为8位的sey的数据,在lam里面可以加载 ,也可以正常显示,但是加到geoframe里面的时候就不行,加是加进去了,就是看到的剖面或切片不对劲,都是一个值。
    到底是什么问题啊??
    我用dump看segy数据的时候发现前面一段很乱,都是斜线之类的,反正不是文字,
    还有加载的参数,哪个first data sample 怎么老是默认的是109(16bit)
    下面是我的加载segy的log:
    Project: dm_3d
    *I*
    *I* Loading inline data
    3D Seismic class: coh500
    3D Survey: bhh3d
    *I*
    *I* Checking seismic dsl spanning criteria
    *I* Using percentage free:                   5.0000     %
    *I*
    *I* /data2/gf44_proj/DM_3D/Default/
    *I* dsl size     :   240092426
    *I* dsl available:   58821502
    *I* percentage free: 24 %
    *I*
    *I* Spanning seismic dsl criteria satisfied
    *I*
    *I* Survey line increment: -1
    *I* Input line increment: 2
    *I* Survey CDP increment: 1
    *I* Input CDP increment: 1
    *I* Nth trace to load: 2
    *I* Loading CDP increment: 2
    *I* Deleting seismic volume:
    *I* Seismic volume deleted
    *I* Resetting survey limits
    *I* Survey limits reset
    3-D Line loading
    .Opening new disk file:
    /data3/liujp/dm/1000-1500-coh.sgy
    *Warn* Override input trc/rec,was: 0 Now is: 1
    *I* Looking for inline: 802.Found: 802.
    *I* Looking for CDP 1627. Found 1627.
    *I* Line 802,CDP 1627
    *I* Loading Inline: 802
    *I* Setting current seismic volume
    *I* Created empty seismic volume for subsequent loading
    *I* TFS Non-multiple of sample rate:                   3.0000
    *I* Using:                   2.0000
    *Warn* TFS Non-multiple of sample rate:                   3.0000
    *Warn* Using:                   2.0000
    *I* Integrity fail, @CDP 1629.
    *I* Expected: 1628. Found: 1629.
    *I* Integrity fail, @CDP 1631.
    *I* Expected: 1630. Found: 1631.
    *I* Pad from CDP 1629 to 1629.
    *I* Integrity fail, @CDP 1633.
    *I* Expected: 1632. Found: 1633.
    *I* Integrity fail, @CDP 1635.
    *I* Expected: 1634. Found: 1635.
    *I* Pad from CDP 1633 to 1633.
    *I* Integrity fail, @CDP 1637.
    *I* Expected: 1636. Found: 1637.
    *I* Integrity fail, @CDP 1639.
    *I* Expected: 1638. Found: 1639.
    *I* Pad from CDP 1637 to 1637.
    *I* Integrity fail, @CDP 1641.
    *I* Expected: 1640. Found: 1641.
    *I* Integrity fail, @CDP 1643.
    *I* Expected: 1642. Found: 1643.
    *I* Pad from CDP 1641 to 1641.
    *I* Integrity fail, @CDP 1645.
    *I* Expected: 1644. Found: 1645.
    *I* Integrity fail, @CDP 1647.
    *I* Expected: 1646. Found: 1647.
    *I* Pad from CDP 1645 to 1645.
    *I* Integrity fail, @CDP 1649.
    *I* Expected: 1648. Found: 1649.
    *I* Integrity fail, @CDP 1651.
    *I* Expected: 1650. Found: 1651.
    *I* Pad from CDP 1649 to 1649.
    *I* Integrity fail, @CDP 1653.
    *I* Expected: 1652. Found: 1653.
    *I* Integrity fail, @CDP 1655.
    *I* Expected: 1654. Found: 1655.
    *I* Pad from CDP 1653 to 1653.
    *I* Integrity fail, @CDP 1657.
    *I* Expected: 1656. Found: 1657.
    *I* Integrity fail, @CDP 1659.
    *I* Expected: 1658. Found: 1659.
    *I* Pad from CDP 1657 to 1657.
    *I* Integrity fail, @CDP 1661.
    *I* Expected: 1660. Found: 1661.
    *I* Integrity fail, @CDP 1663.
    *I* Expected: 1662. Found: 1663.
    *I* Pad from CDP 1661 to 1661.
    *I* Integrity fail, @CDP 1665.
    *I* Expected: 1664. Found: 1665.
    *I* Integrity fail, @CDP 1667.
    *I* Expected: 1666. Found: 1667.
    *I* Pad from CDP 1665 to 1665.
    *I* Integrity fail, @CDP 1669.
    *I* Expected: 1668. Found: 1669.
    *I* Integrity fail, @CDP 1671.
    *I* Expected: 1670. Found: 1671.
    *I* Pad from CDP 1669 to 1669.
    *I* Integrity fail, @CDP 1673.
    *I* Expected: 1672. Found: 1673.
    *I* Integrity fail, @CDP 1675.
    *I* Expected: 1674. Found: 1675.
    *I* Pad from CDP 1673 to 1673.
    *I* Integrity fail, @CDP 1677.
    *I* Expected: 1676. Found: 1677.
    *I* Integrity fail, @CDP 1679.
    *I* Expected: 1678. Found: 1679.
    *I* Pad from CDP 1677 to 1677.
    *I* Integrity fail, @CDP 1681.
    *I* Expected: 1680. Found: 1681.
    *I* Integrity fail, @CDP 1683.
    *I* Expected: 1682. Found: 1683.
    *I* Pad from CDP 1681 to 1681.
    *I* Integrity fail, @CDP 1685.
    *I* Expected: 1684. Found: 1685.
    *I* Integrity fail, @CDP 1687.
    *I* Expected: 1686. Found: 1687.
    *I* Pad from CDP 1685 to 1685.
    *I* Integrity fail, @CDP 1689.
    *I* Expected: 1688. Found: 1689.
    *I* Integrity fail, @CDP 1691.
    *I* Expected: 1690. Found: 1691.
    *I* Pad from CDP 1689 to 1689.
    *I* Integrity fail, @CDP 1693.
    *I* Expected: 1692. Found: 1693.
    *I* Integrity fail, @CDP 1695.
    *I* Expected: 1694. Found: 1695.
    *I* Pad from CDP 1693 to 1693.
    *I* Integrity fail, @CDP 1697.
    *I* Expected: 1696. Found: 1697.
    *I* Integrity fail, @CDP 1699.
    *I* Expected: 1698. Found: 1699.
    *I* Pad from CDP 1697 to 1697.
    *I* Integrity fail, @CDP 1701.
    *I* Expected: 1700. Found: 1701.
    *I* Integrity fail, @CDP 1703.
    *I* Expected: 1702. Found: 1703.
    *I* Pad from CDP 1701 to 1701.
    *I* Integrity fail, @CDP 1705.
    *I* Expected: 1704. Found: 1705.
    *I* Integrity fail, @CDP 1707.
    *I* Expected: 1706. Found: 1707.
    *I* Pad from CDP 1705 to 1705.
    *I* Integrity fail, @CDP 1709.
    *I* Expected: 1708. Found: 1709.
    *I* Integrity fail, @CDP 1711.
    *I* Expected: 1710. Found: 1711.
    *I* Pad from CDP 1709 to 1709.
    *I* Integrity fail, @CDP 1713.
    *I* Expected: 1712. Found: 1713.
    *I* Integrity fail, @CDP 1715.
    *I* Expected: 1714. Found: 1715.
    *I* Pad from CDP 1713 to 1713.
    *I* Integrity fail, @CDP 1717.
    *I* Expected: 1716. Found: 1717.
    *I* Integrity fail, @CDP 1719.
    *I* Expected: 1718. Found: 1719.
    *I* Pad from CDP 1717 to 1717.
             *Warn* Found trace on next inline 806 *Unexpected*
    *I* Pad from CDP 2521 to 3547.
    *I* ** End inline 804.
    *I* ** End CDP 2519.
    *I* ** ACCEPTED 224 Traces.
    *I* ** Padded..: 737 dead traces
    *I* ===================================
    Closing IESX line
    *I* Looking for inline: 806.Found: 806.
    *I* Line 806,CDP 1627
    *I* Loading Inline: 806
    *I* Using:                   2.0000
  • 签到天数: 18 天
    发表于 2009-9-22 22:34:59 | 显示全部楼层
    最好能看看你的加载过程    按理说只要是sgy格式  什么数据都没有问题的
  • 签到天数: 7 天
    发表于 2009-10-1 19:23:52 | 显示全部楼层
    可能数据体有问题,在看看工区的坐标系统,geoframe加载sey的格式试试别的格式看看,那里面有好几个选项,别用默认的、
    发表于 2009-10-7 15:05:03 | 显示全部楼层
    你在其他软件中最好生成16或者32位的相干数据体,然后在geoframe中加为8位
    发表于 2010-12-24 23:58:59 | 显示全部楼层
    可能segy格式选定不对
    2016-4-26 08:57
  • 签到天数: 29 天
    发表于 2012-3-30 11:38:20 | 显示全部楼层
    试试看
  • 签到天数: 174 天
    发表于 2012-4-1 14:50:28 | 显示全部楼层
  • 签到天数: 490 天
    发表于 2013-5-22 20:09:30 | 显示全部楼层
    LZ你用什么软件做的相干体!
    GMT+8, 2026-2-20 15:50 , Processed in 0.075028 second(s), 23 queries .
