查看: 613|回复: 3
[Petrel RE] simulation的grid property modifications
发表于 2019-1-25 12:57:33 | 显示全部楼层 |阅读模式
想请教一下关键字PERMX与PERMI的区别,我用PETRELRE做数模我的模型是用的PERMX定义的,但是后边数模时候我用simulation的grid property modifications 对我的CASE修改渗透率时候,建立PROPERTIES时候没成功,错误提示:“Could not create modified properties: Calculation of modified properties failed
- The property "XYdirection  Edit_Perm" used for keyword "PERMX" is changed by a Grid Property Modifier, but has been reused for at least one other keyword in the case. To avoid incorrect changes to the other keywords, assign a property that is not reused.
No properties will be modified.”请高手帮忙解答
  • 签到天数: 94 天
    发表于 2019-2-21 20:56:02 | 显示全部楼层
    最好上图看一下,大体能看出来是定义GPM的时候出的问题。但是跟PERMI无关,正常关键字就是PERMX.
  • 签到天数: 380 天
    发表于 2021-7-22 10:53:35 | 显示全部楼层
    学习学习~!
    发表于 2021-7-23 12:59:53 | 显示全部楼层
    非常感谢,祝论坛越办越好!
    GMT+8, 2025-5-12 18:14 , Processed in 0.047982 second(s), 20 queries .
