查看: 522|回复: 2
[基本理论] 海湾月光的博客
发表于 2019-1-25 09:26:10 | 显示全部楼层 |阅读模式
哪位大神告诉我一下海湾月光的博客啊?
    发表于 2019-1-25 10:57:14 | 显示全部楼层
    应该早就不更新了吧
     楼主| 发表于 2019-1-25 12:52:21 | 显示全部楼层
    想请教一下关键字PERMX与PERMI的区别,我用PETRELRE做数模我的模型是用的PERMX定义的,但是后边数模时候我用simulation的grid property modifications 对我的CASE修改渗透率时候,建立PROPERTIES时候没成功,错误提示:“Could not create modified properties: Calculation of modified properties failed
    - The property "XYdirection  Edit_Perm" used for keyword "PERMX" is changed by a Grid Property Modifier, but has been reused for at least one other keyword in the case. To avoid incorrect changes to the other keywords, assign a property that is not reused.
    No properties will be modified.”请高手帮忙解答
    GMT+8, 2025-7-15 05:48 , Processed in 0.048873 second(s), 20 queries .
