查看: 810|回复: 1
[CMG] Winprop 入门例子
  • 签到天数: 5 天
    发表于 2018-8-18 05:45:42 | 显示全部楼层 |阅读模式
    干气,凝析气等五种流体的两相计算示例与实例;稠油模型包括分成pseudocomponent等操作的示例。五种流体参数
    Mole Fractions
    Component
    Dry Gas
    Wet Gas
    Gas Condensate
    Volatile Oil
    Black Oil
    CO2
    0.1
    1.41
    2.37
    0.93
    0.02
    N2
    2.07
    0.25
    0.31
    0.21
    0.34
    C1
    86.12
    92.46
    74.19
    63.77
    34.62
    C2
    5.91
    3.18
    7.8
    7.57
    4.11
    C3
    3.58
    1.01
    3.55
    4.09
    1.01
    IC4
    1.72
    0.28
    0.71
    0.91
    0.76
    NC4
    0.24
    1.45
    2.09
    0.49
    IC5
    0.5
    0.13
    0.64
    0.77
    0.43
    NC5
    0.08
    0.68
    1.15
    0.21
    FC6
    0.14
    1.09
    1.75
    1.61
    C7+
    0.82
    7.21
    16.76
    56.4
    C7+ properties
    Specific  gravity
    0.763
    0.816
    0.858
    0.92
    Molecular  weight
    130
    184
    228
    274
    Reservoir Temperature (F)
    180
    220
    280
    210
    170
    稠油的参数
    API
    11.57
    Composition of C1 Gas to be Added (STEP 3)
    0.08223
    Two-Phase Flash Calculation Data (STEP 12)
    10 deg C
    Temp (C)
    12
    Calculations  Tab
    GOR (m3/m3)
    7
    Plus Fraction Splitting Sample 1 Tab Data for Input  (STEP 5)Pressure
    101.325
    Mole Fraction
    Molecular Weight
    Temperature
    10
    Pres (kPa)
    3200
    0.000458885
    84
    Experimental  Tab
    0.009361254
    94.54520941
    Liquid Viscosity
    79500
    Temp.Viscosity0.014041881
    104.0451886
    (C)(mPa.s)0.018447177
    116.7930597
    100 deg C
    10
    79500
    0.031295957
    132.8256769
    Calculations  Tab
    100
    56.3
    0.037445016
    147
    Pressure
    101.325
    0.035884807
    161
    Temperature
    100
    0.048091148
    175
    Experimental  Tab
    0.049284249
    190
    Liquid Viscosity
    56.3
    0.048550033
    206
    0.045154284
    222
    0.048458256
    237
    0.038362786
    251
    0.036802577
    263
    0.034049267
    275
    0.031020626
    291
    0.028083762
    300
    0.029001532
    312
    0.020833379
    324
    0.021842926
    337
    0.019548501
    349
    0.016428083
    360
    0.016336306
    372
    0.016244529
    382
    0.222742779
    500
    Specific Gravity
    0.989
    Saturation  Pressure Values (STEP 10)
    Temperature
    12
    Saturation Pressure Estimate
    3200
    Saturation Pressure Measurement
    3200
    Separator  Values (STEP 10)
    Sat. Pres.
    Stock Tank
    Pres.
    3200
    101.325
    Temp
    12
    15.556
    Name
    Pres.
    Temp.
    Oil
    101.325
    15.556
    Gas
    101.325
    15.556
    Separator  Values Experimental Tab (STEP 10)
    GOR
    7
    Weight
    1
    API
    11.6
    Weight
    1
    PBM and PVT Creation Using WinProp Tutorial.pdf
    4.04 MB, 下载次数: 17
    售价: 2 阳光币  [记录]
  • 签到天数: 6 天
    发表于 2018-8-18 15:23:26 | 显示全部楼层
    受教了
    GMT+8, 2025-2-24 10:14 , Processed in 0.059415 second(s), 23 queries .
