查看: 24484|回复: 44
英国PetEx公司数字化油田解决方案
发表于 2018-8-10 10:02:15 | 显示全部楼层 |阅读模式
下载PDF文件:
The Digital Oil Field software applications replicate the behaviour of an oil or gas field on a computer, using workflows for automation and clusters to speed up calculations. The applications are used as an on-line management system throughout the entire lifecycle of any asset.
The Petroleum Experts DOF technology provides an enterprise-level, vendor-neutral approach that allows companies to extract maximum value from the available information relating to reservoirs, wellbores, and surface facilities.
This enables rational decision making through the use of models, workflows, and intelligently filtered data within a multi-disciplinary organisation of diverse capabilities and engineering skill sets.
  • No programming required – Visual Workflows
  • Straight forward to deploy (only configuration required, no coding)
  • Technology is upgradable, extensible, scalable
  • Over 100 workflows addressing:
    • Well Test Validation and diagnostics associated with PVT checks
    • Well Surveillance
    • Any equipment quality control
    • Total system quality control
    • Optimisation of different types
    • Forecasting, with and without optimisation
    • Workflows can be easily modified to achieve any engineering objective
 楼主| 发表于 2018-8-10 10:03:43 | 显示全部楼层
更多信息,请注册访问阿什卡公司技术支持资源中文网站:www.essca.com
  • 签到天数: 1201 天
    发表于 2018-8-10 11:02:14 | 显示全部楼层
    学习学习~
     楼主| 发表于 2018-8-10 11:06:04 | 显示全部楼层
    很牛的一家公司,做了很多DOF项目,水平很高。
  • 签到天数: 254 天
    发表于 2018-8-11 14:28:39 | 显示全部楼层
     楼主| 发表于 2018-8-12 11:53:41 | 显示全部楼层
  • 签到天数: 49 天
    发表于 2018-12-20 10:01:36 | 显示全部楼层
     楼主| 发表于 2018-12-20 10:56:46 | 显示全部楼层
    发表于 2019-2-19 22:04:06 | 显示全部楼层
    谢谢
     楼主| 发表于 2019-2-23 18:36:25 | 显示全部楼层
    不客气。周末愉快!
    GMT+8, 2026-6-18 00:20 , Processed in 0.057556 second(s), 27 queries .
