高放废物深地质处置中耦合的热学-水力学-力学-化学过程——以监管研究为例 原文网址:http://www.astp-agr.com/index.php/Index/Index/detail?id=62
加拿大和许多其他国家正在考虑将深层地质处置作为放射性废物长期管理最可靠的方法。处置方法包括将废物放置在数百米深的稳定地层中的处置库中。由主岩层作为主要构成部分的多层屏障系统,可长期保护人类和环境免受废物的有害影响。很多反应过程将会在处置库的整个生命周期中进行,例如废物的热发生,地震活动和冰川。因此多重屏障系统的自然和工程部件中的热-水力-机械-化学(THMC)体系将受到这些反应的干扰,故必须理解THMC体系的演变以及这种演变如何影响多层屏障系统的过程。 加拿大核监管机构(CNSC)、加拿大核安全委员会数十年来一直在进行THMC耦合工艺的独立实验和理论研究。作为这项研究的一部分,委员会利用了实验室测试和地下研究实验室(URL)的大尺度实验的实验数据,来开发模拟工程和天然地质处理屏障耦合过程的数学框架。最近,加拿大和安全委员会的Thanh Son Nguyen教授描述了这个数学框架,并展示了它是如何适应和应用于以下几种情况的:URL中的水和气体注入实验,URL中的加热器实验以及九个冰川旋回在沉积岩中的影响。
Thermo-Hydro-Mechanical-Chemical processes in geological disposal of radioactive waste – An example of regulatory research Thanh Son Nguyen CorrespondingAuthor and Email: Thanh Son Nguyen, son.nguyen@canada.ca
Citation: Nguyen, T.S. Thermo-Hydro-Mechanical-Chemical processes in geological disposal of radioactive waste – An example of regulatory research. Advances in Geo-Energy Research, 2018, 2(2): 173-189, doi: 10.26804/ager.2018.02.06.
ArticleType: Original article
Abstract:
Deep geological disposal is being considered in Canada and many other countries as the most viable option for the long-term management of radioactive waste. The disposal method consists of emplacing the waste in a repository built at hundreds of metres depth in a suitable host rock. A multi-barrier system, that includes the host rock formation as a major component, would be provided in order to protect humans and the environment from the harmful effects of the waste for very extensive time periods. Many events and processes are expected to occur during the lifetime of the repository, such as heat generation from the waste, seismicity and glaciation. As a result of those events and processes the Thermal-Hydraulic-Mechanical-Chemical (THMC) regimes in the natural and engineered components of the multi-barrier system will be perturbed, and the evolution of the THMC regimes and how this evolution affects the multi-barrier performance need to be understood. The Canadian Nuclear Safety Commission (CNSC), Canada’s nuclear regulator, has been conducting independent experimental and theoretical research on coupled THMC processes for several decades. As part of this research, the CNSC used experimental data from laboratory tests and large-scale experiments at underground research laboratories (URL) in order to develop a mathematical framework for the simulation of coupled processes in engineered and natural barriers for geological disposal. In this paper, we describe that mathematical framework and show examples of how it was adapted and applied to several situations: water and gas injection experiment at an URL, a heater experiment at an URL, and the effects of nine glacial cycles in a sedimentary rock formation. Keywords: Radioactive wastes, geological disposal, coupled processes
