查看: 524|回复: 0
【2018,2(1):43-52】Experimental study on evolution behaviors of triaxia...
发表于 2018-2-7 12:44:07 | 显示全部楼层 |阅读模式
Experimental study on evolution behaviors of triaxial-shearing parameters for hydrate-bearing intermediate fine sediment
Yanlong Li, Changling Liu, Lele Liu, Jianye Sun, Haojia Liu, Qingguo Meng
(Published: 2018-02-02)
Corresponding Author and Email: Changling Liu, qdliuchangling@163.com
Citation: Li, Y., Liu, C., Liu, L., Sun, J., Liu, H., Meng, Q. Experimental study on evolution behaviors of triaxial-shearing parameters for hydrate-bearing intermediate fine sediment. Advances in Geo-Energy Research, 2018, 2(1): 43-52, doi: 10.26804/ager.2018.01.04.
Abstract:
Evolution behaviors of triaxial shearing parameters are very important for geo-technical response analysis during the process of extracting natural gas from hydrate-bearing reservoirs. In order to explore the effects of hydrate formation/decomposition on triaxial shearing behaviors of intermediate fine sediment, natural beach sand in Qingdao, China, which was sieved from 0.1 mm to 0.85 mm, was used and a series of triaxial shear tests were carried out in this paper. The principle of critical state was firstly used to explain the mechanism of strain softening and/or hardening failure mode. Moreover, an empirical model was provided for axial-lateral strain and corresponding model parameters calculation. Evolution rules of critical strength parameters were analyzed prominently. The results show that failure mode of sediment is controlled by several parameters, such as effective confining pressure, hydrate saturation, etc. Different axial-lateral strain model coefficients’ effect on strain relationships are different, probing into the physical meaning of each coefficient is essential for further understanding of strain relationships. Complex geotechnical response should be faced with the progress of producing natural gas from hydratebearing reservoir, because of sudden change of failure pattern and formation modulus. Further compressive study on critical condition of failure pattern is needed for proposed promising hydrate-bearing reservoirs.
Keywords: Hydrate-bearing sediments, strain-hardening, strain-softening, triaxial shear strength, intermediate fine sediment.
5a77dcb57677d.pdf (5.66 MB, 下载次数: 7)
GMT+8, 2025-3-14 23:04 , Processed in 0.051637 second(s), 22 queries .
