查看: 359|回复: 1
【2017,1(3):190-202】Controlling factors and physical property cutoffs of the...
发表于 2017-12-21 18:07:09 | 显示全部楼层 |阅读模式
Controlling factors and physical property cutoffs of the tight reservoir in the Liuhe Basin
Zhaozhao Tan, Weiming Wang, Wenhao Li, Shuangfang Lu, Taohua He
(Published: 2017-12-25)
Corresponding Author and Email: Weiming Wang, 41560387@qq.com
Citation: Tan, Z., Wang, W., Li, W., et al. Controlling factors and physical property cutoffs of the tight reservoir in the Liuhe Basin. Adv. Geo-energ. Res. 2017, 1(3): 190-202, doi: 10.26804/ager.2017.03.06.
Abstract:
Tight gas sandstone reservoirs of the Lower Cretaceous Xiahuapidianzi Formation are the main exploration target in the Liuhe Basin in China. Petrology characteristics, reservoir space (pore space), controlling factors and physical property cutoffs of the tight sandstone reservoir in the Liuhe Basin were determined through the integrated analysis of several methods including: casting thin section, field emission scanning electron microscopy (FE-SEM), X-ray diffraction (XRD), mercury intrusion porosimetry (MIP), nuclear magnetic resonance (NMR) and nitrogen gas adsorption (N2GA). The sandstones dominated by lithic arkoses and feldspathic litharenites are characterized by low porosity, low permeability and strong microscopic heterogeneity. The porosity has a range between 0.48% and 4.80%, with an average of 2.26%. Intercrystalline pores, intergranular pores, dissolved pores and microfractures can be observed through the casting thin section and FE-SEM images. Compaction and carbonate cementation are the two primary mechanisms resulting in the low porosity of the Liuhe sandstones. Microfractures improve the permeability of the tight sandstones and provide pathways for fluid migration and the storage of hydrocarbon accumulations. Moreover, the theoretical cutoff of the porosity in the Xiahuapidianzi Formation tight sandstones is 3.3%.
Keywords: Reservoir space, controlling factors of physical properties, physical property cutoffs, water film, tight reservoir.
Controlling factors and physical property cutoffs of the tight reservoir in the .pdf
6.56 MB, 下载次数: 3
 楼主| 发表于 2017-12-21 18:10:24 | 显示全部楼层
AGER期刊第三期最新论文已更新,欢迎专家学者们阅读与提出宝贵意见。
GMT+8, 2024-6-26 23:18 , Processed in 0.068374 second(s), 22 queries .
