查看: 475|回复: 1
AGER 期刊1卷1期2期电子版豆丁网下载开通,敬请关注。
发表于 2017-12-14 04:18:17 | 显示全部楼层 |阅读模式
《Advances in Geo-Energy Research》期刊第1期和第2期电子版
为使作者论文与理念得到最快速地传播与尽可能多的引用,已将AGER期刊第一期与第二期论文部分上传至豆丁、道客巴巴、百度文库、领英等各大文档类与社交类传播迅速的平台。以下是前两期部分文章于豆丁网的下载地址,感谢各位专家和学者的支持,后续将推出官方期刊公众号与读者交流群,敬请关注!
1.A critical review on fundamental mechanisms of spontaneous..   http://www.docin.com/p-2035487104.html
2.Applications of digital core analysis and hydraulic flow u..          http://www.docin.com/p-2035496287.html
3. Review on gas flow and recovery in unconventional porous r..   http://www.docin.com/p-2035501109.html
4.A review of stimulated reservoir volume characterization f..         http://www.docin.com/p-2035502374.html
5.The study of relative permeability and residual gas satura..           http://www.docin.com/p-2035504233.html
6.Insights on the gas permeability change in porous shale                 http://www.docin.com/p-2035507853.html
7.Non-Darcy displacement by a non-Newtonian fluid in porous..    http://www.docin.com/p-2035509070.html
8.A new model for calculating permeability of natural fractu..            http://www.docin.com/p-2035510092.html
9.Quantitative characterization of micropore structure for o..           http://www.docin.com/p-2035515761.html
10.A study of correlation between permeability and pore space..      http://www.docin.com/p-2035511302.html
11.An analysis of the key safety technologies for natural gas..         http://www.docin.com/p-2035512486.html
12.The new method on gas-water two phase steady-state product.. http://www.docin.com/p-2035514874.html
13.Review on Dynamic Van der Waals Theory in two-phase flow   http://www.docin.com/p-2035517062.html
扫描二维码关注”AGER期刊”微信公众号
参与人数 1阳光币 +30 贡献 +18 收起 理由
xinmeng + 30 + 18 发贴规范,加分鼓励
 楼主| 发表于 2017-12-14 05:13:44 | 显示全部楼层
GMT+8, 2025-7-9 21:31 , Processed in 0.054729 second(s), 23 queries .
