查看: 451|回复: 0
【2017,1(2):74-85】Non-Darcy displacement by a non-Newtonian fluid in porous ...
发表于 2017-11-13 00:01:04 | 显示全部楼层 |阅读模式
Non-Darcy displacement by a non-Newtonian fluid in porous media according to the Barree-Conway model
Zhaoqin Huang, Xiaoyu Zhang, Jun Yao, Yushu Wu
(Published: 2017-09-25)
Corresponding Author and Email: Jun Yao, emc.group.upc@gmail.com
Citation: Huang, Z., Zhang, X., Yao, J., et al. Non-Darcy displacement by a non-Newtonian fluid in porous media according to the Barree-Conway model. Adv. Geo-energ. Res. 2017, 1(2): 74-85, doi: 10.26804/ager.2017.02.02.
Abstract:
An analytical solution for describing the non-Darcy displacement of a Newtonian fluid by a non-Newtonian fluid in porous media has been developed. The two-phase non-Darcy flow is described using the Barree-Conway model under multiphase conditions. A power-law non-Newtonian fluid, whose viscosity is a function of the flow potential gradient and the phase saturation, is considered. The analytical solution is similar to the Buckley-Leverett theoretical solution, which can be regarded as an extension of the Buckley-Leverett theory to the non-Darcy flow of non-Newtonian fluids. The analytical results revel how non-Darcy displacement by a non-Newtonian fluid is controlled not only by relative permeabilities but also by non-Darcy flow coefficients as well as non-Newtonian rheological constitutive parameters and injection rates. The comparison among Darcy, Forchheimer and Barree-Conway models is also discussed. For application, the analytical solution is then applied to verify a numerical simulator for modeling multi-phase non-Darcy flow of non-Newtonian fluids.
Keywords: Non-Newtonian fluid, non-darcy flow, barree-conway model, buckley-leverett type solution, two-phase immiscible flow.
2.Non-Darcy displacement by a non-Newtonian fluid in porous media according to t.pdf
1.71 MB, 下载次数: 1
GMT+8, 2025-7-9 18:28 , Processed in 0.050843 second(s), 22 queries .
