查看: 455|回复: 1
【2017,1(1):18-30】Applications of digital core analysis and hydraulic flow u...
发表于 2017-11-12 23:14:50 | 显示全部楼层 |阅读模式
Applications of digital core analysis and hydraulic flow units in petrophysical characterization
Xiaojun Chen, Yingfang Zhou
(Published: 2017-06-25)
Corresponding Author and Email: Xiaojun Chen, chenxiaojuncug@hotmail.com
Citation: Chen, X., Zhou, Y. Applications of digital core analysis and hydraulic flow units in petrophysical characterization. Adv. Geo-energ. Res. 2017, 1(1): 18-30, doi: 10.26804/ager.2017.01.02.
Article Type: Invited review
Abstract:
Conventional petrophysical characterizations are often based on direct laboratory measurements. Although they provide accurate results, such measurements are time-consuming and limited by instrument and environment. What’s more, in the geo-resource energy industry, availability and cuttings of core plugs are time consuming and difficult. Because of these reasons, virtual digital core technology is of increasing interest due to its capability of characterizing rock samples without physical cores and experiments. Virtual digital core technology, also known as digital rock physics, is used to discover, understand and model relationships between material, fluid composition, rock microstructure and macro equivalent physical properties. Based on actual geological conditions, modern mathematical methods and imaging technology, the digital model of the core or porous media is created to carry out physical field numerical simulation. In this review, the methods for constructing digital porous media are introduced first, then the characterization of thin rock cross section and the capillary pressure curve using scanning electron microscope image under mixed wetting are presented. Finally, we summarize the hydraulic flow unit methods in petrophysical classification.
Keywords: Digital core, porous media, petrophysical characterization, thin section, mercury injection capillary pressure.
2.Applications of digital core analysis and hydraulic flow units in petrophysica.pdf
1.96 MB, 下载次数: 3
参与人数 1阳光币 +10 贡献 +10 收起 理由
xinmeng + 10 + 10 精品资料,感谢楼主
  • 签到天数: 4 天
    发表于 2017-11-15 20:30:11 | 显示全部楼层
    谢谢!
    GMT+8, 2025-4-19 13:20 , Processed in 0.052356 second(s), 26 queries .
