查看: 1325|回复: 0
[经验分享] Geomechanical stratification in a shale reservoir
  • 签到天数: 28 天
    发表于 2017-11-5 22:33:46 | 显示全部楼层 |阅读模式
    Geomechanical stratification in a shale reservoir and its correlation with natural fractures: case from Pomeranian Basin (Poland).
    Pachytel Radomir W., Jarosiński Marek and Bobek Kinga
    Polish Geological Institute – National Research Institute, Warsaw, Poland
    ABSTRACT:Mechanical stratification of shale complexes is an important feature of tight reservoir that controls both: the pattern of natural tectonic strata-bound fractures and propagation of technological hydraulic fractures. In our study we are looking for factors controlling the mechanical properties of a shale complex and define parameters crucial to distinguish geomechanically consistent units based on core and borehole geophysical data. We describe the hierarchic system of Consistent Lithological Units (CLUs) to ease compilation and extrapolation of analyses at different scales and resolution. Higher level member (CLU3) are traceable from well to well at distances of tens of kilometers across the Baltic Basin. The dependence between mineralogical composition and elastic modulus with emphasis on the role of calcite is analyzed. The results show that carbonates may have had a stronger impact on the Young’s modulus and brittleness index growth than quartz. These observations led us to modify the conventionally used mineralogical brittleness index by incorporation of TOC factor and determination of the calcite placement in the formula numerator. We also compare the intensity of vertical and horizontal fractures with the calculated brittleness index and conclude that the natural fracture density is not a direct function of shale brittleness.
    Geomechanical stratification in a shale reservoir and its correlation with natur.pdf
    1.54 MB, 下载次数: 10
    售价: 1 阳光币  [记录]
    GMT+8, 2025-7-12 09:49 , Processed in 0.052254 second(s), 23 queries .
