查看: 5343|回复: 15
CCS科普贴
  • 签到天数: 42 天
    发表于 2017-7-26 08:09:01 | 显示全部楼层 |阅读模式
    普及CCS知识,为大家传递权威的CCS讯息
  • 签到天数: 42 天
     楼主| 发表于 2017-7-26 08:17:09 | 显示全部楼层
    What is CCS?
    CCS, or Carbon Capture and Storage, is a working low carbon technology which captures carbon dioxide (CO
    2) from the burning of coal and gas for power generation, and from the manufacturing of steel, cement and other industrial facilities, and transports it by either pipeline or ship, for safe and permanent underground storage, preventing it from entering the atmosphere and contributing to anthropogenic climate change. (From CCSA)
    碳捕集与封存,从燃煤或燃气电厂、钢厂、水泥厂或其他设备中捕集CO2,然后以管道或者船(卡车也是运输方式一种,延长石油的CCS项目以卡车将CO2从榆林煤化工厂运输到神木和靖边的采油厂)运输到封存区,最后将其安全永久的封存到地下,保证CO2不会重新进入大气层以此来为气候变化做贡献。
  • 签到天数: 42 天
     楼主| 发表于 2017-7-26 15:16:41 | 显示全部楼层
    How does CCS work?
    There are three stages to CCS: capture, transport, and safe underground storage.
    CCS技术的三个步骤:捕集、运输、安全封存
    Capture – First, the carbon dioxide is removed, or separated, from coal and gas power plants, and from the manufacturing of steel and cement. There are three types of capture; post-combustion, pre-combustion and oxyfuel combustion. This is called carbon dioxide capture and can captures 90% of carbon dioxide emissions.
    捕集--将CO2从燃煤电厂、钢铁厂、水泥厂的尾气中分离。常用捕集方式有三种:燃烧后捕集、燃烧前捕集、富氧燃烧捕集。这将捕集约90%释放的CO2.
    Transport – The carbon dioxide is then compressed and transported to a suitable storage site. The transport is generally carried out in pipelines. Ship transport is also an option for offshore carbon dioxide transport.
    运输--CO2被压缩然后运输到合适的封存区。通常是通过管道运输。轮船运输对于海上CO2运输是非常好的选择。
    Storage – The carbon dioxide is the injected into a suitable storage site deep below the ground. The storage site must be a geological formation that ensures safe and permanent storage. Storage can either take place in depleted oil & gas fields, or deep saline formations. (From CCSA)
    封存--CO2被注入到地下合适的封存区。封存区必须是可以永久安全封存CO2的地质构造。封存区可以是开发后期的油气田或者地下盐水层构造。
  • 签到天数: 42 天
     楼主| 发表于 2017-7-26 15:18:15 | 显示全部楼层
    原文为英文,中午是我自己翻译的。有啥不准确的地方请大家指正
  • 签到天数: 42 天
     楼主| 发表于 2017-7-27 08:43:23 | 显示全部楼层
    What is a CCS plant? What will it look like?
    A CCS plant is one which captures carbon dioxide from the burning of fossil fuels at coal and gas power plants, and from steel and cement manufacturing plants It is a combination or three parts; capture, transport and storage of carbon dioxide. Depending on the location of the power plant or industrial facility, the carbon dioxide can be transported over long distance for storage.
    CCS plants are typically situated next to the plant from which carbon dioxide is captured. A ‘capture-ready’ power plant is one that has been designed and built for subsequent retrofitting with CCS technology. This requires space to be set aside next to the power plant, as well as an identified pipeline route and storage formation.
    A carbon dioxide pipeline supporting CCS will be very similar in design and scale to pipelines already employed for the transport of natural gas. The same regulations that are applied to all pipelines are applied to Carbon Dioxide ensuring high standards of design and protection of the pipeline and environment. (From CCSA)
  • 签到天数: 42 天
     楼主| 发表于 2017-7-27 08:45:16 | 显示全部楼层
    How does it work with coal and gas plants?
    CCS removes or “captures” the carbon dioxide produced from coal or gas fired generation and transports it for safe underground storage. There are three ways capture can be done:
    Post-combustion capture
    Carbon dioxide can be captured from the exhaust of a coal or gas power plant by absorbing it in a solvent. The absorbed carbon dioxide is removed from the solvent and then compressed for transport and safe underground storage. The solvent is recycled as part of an environmentally responsible process.
    Pre-combustion capture
    The coal or gas is pre-treated and converted into a mix of hydrogen and carbon dioxide, with the carbon dioxide separated, compressed and transported for safe underground storage. The hydrogen produced can then be used as a zero-carbon fuel.
    “Oxy-fuel” combustion systems
    The coal or gas is burned in oxygen instead of air, which then produces a more concentrated carbon dioxide stream for easier separation.
  • 签到天数: 42 天
     楼主| 发表于 2017-7-27 15:07:14 | 显示全部楼层
    What is carbon dioxide?
    Carbon dioxide (CO2) is a naturally occurring gas, found in the atmosphere. Carbon dioxide is all around us. We breathe out carbon dioxide and it is a vital gas for plant life. Carbon Dioxide has been used on industrial sites and in food manufacturing for many decades, including in soft drinks and fire extinguishers.
    We also emit carbon dioxide from power generation, driving cars, aviation and homes, all of which we need to tackle if we are to limit the effects of climate change.
    Although carbon dioxide in the atmosphere is essential to maintain a climate habitable by people, too much carbon dioxide in the atmosphere can lead to potentially harmful climate change. Carbon dioxide is the most important anthropogenic greenhouse gas. According the IPCC, the global atmospheric concentration of carbon dioxide has increased from a pre-industrial value of about 280 parts per million (ppm) to 379 ppm in 2005. The atmospheric concentration of carbon dioxide in 2005 exceeds by far the natural range over the last 650,000 years (180 to 300 ppm) as determined from ice cores.
    To limit average climate change to less than 2°C, the IPCC states that atmospheric carbon dioxide should be kept below 450ppm. Atmospheric carbon dioxide can also cause ocean acidification, which damages the marine ecosystem. This is why we are developing CCS - to limit the carbon dioxide from entering the atmosphere and causing climate change.
  • 签到天数: 42 天
     楼主| 发表于 2017-7-27 22:01:52 | 显示全部楼层
    Is carbon dioxide dangerous?
    Carbon dioxide (CO2) is all around us. We breathe out carbon dioxide and it is a vital gas for plant life. Carbon dioxide has been used for many decades in industrial processes, in food manufacturing, including soft drinks, and is an essential component of other everyday items such as fire extinguishers.
    In very high concentrations carbon dioxide can be dangerous to humans, having an adverse impact on respiration. Like any dense gas that can displace the air that we breathe, in very high concentrations carbon dioxide can act as an asphyxiant. Where carbon dioxide is handled in very high concentrations, regulations are in place to minimise risks to human health and the environment.
    Exposure limits[1] set by the Health & Safety Executive (HSE, the UK regulator for health and safety) regulate exposure to carbon dioxide for workers in the same manner as other potentially hazardous substances.
  • 签到天数: 42 天
     楼主| 发表于 2017-7-28 08:51:58 | 显示全部楼层
    CCS: CaptureWhat does CCS capture?
    Carbon Capture & Storage (CCS) can capture around 90% of the carbon dioxide (CO2) from the burning of coal and gas (and even biomass) for power; also from the production of steel, cement and other industrial processes. The capture of carbon dioxide is the first part of the three-part CCS chain, comprising capture, transport and storage.
    How does CCS capture carbon dioxide from burning coal and gas for electricity?
    There are three basic approaches:
    Carbon dioxide can be captured from the exhaust of a coal or gas power plant – or from a manufacturing process such as for cement - by dissolving it in a specially formulated liquid. The concentrated carbon dioxide is then removed from the liquid and compressed for transport to safe underground storage. The liquid is recycled as part of an environmentally responsible process.
    The coal or gas is pre-treated and converted into a mix of hydrogen and carbon dioxide.  The carbon dioxide is then separated, compressed and transported to safe underground storage. The hydrogen produced is then used as a zero-carbon fuel.
    The coal or gas is burned in oxygen instead of air.  This produces a more concentrated carbon dioxide stream for easier purification prior to compression and transport to safe underground storage.
  • 签到天数: 42 天
     楼主| 发表于 2017-7-31 22:01:35 | 显示全部楼层
    How much carbon dioxide can be captured through CCS?
    CCS can capture 90% of carbon dioxide emissions from power generation and the production of steel and cement. On a typical (900MW) coal fired power plant with CCS, this means that the emission of 5 million tonnes of carbon dioxide can be avoided each year – the equivalent of taking over 2 million cars off the road.
    How much experience does industry have in capturing carbon dioxide?
    CCS plants are operational today. There are currently 4 operational commercial-scale CCS plants globally:
    Sleipner is in the North Sea, about 160 miles west of Stavanger, Norway: operational since 1996 and injecting over 1 million tonnes of carbon dioxide annually
    Weyburn is in southeastern Saskatchewan, Canada: operational since 2005 and injecting 26 million tonnes over the lifetime of the project
    In Salah is in central Algeria: operational since 2004 and injecting over 1 millions tonnes of carbon dioxide annually
    The Snøvit plant in northern Norway: operational since 2008 and, at full production, the plant has a capture and storage capacity of 700,000 tonnes of carbon dioxide per year.
    The first demonstration plant in the UK will be operational from 2015.
    Industry has four decades experience in transporting carbon dioxide in the US for the purposes of enhanced oil recovery.
    GMT+8, 2025-4-19 05:48 , Processed in 0.058884 second(s), 19 queries .
