查看: 728|回复: 3
[资料贴] 各向异性裂缝预测文章
  • 签到天数: 198 天
    发表于 2017-4-23 11:43:54 | 显示全部楼层 |阅读模式
    分享文章
    1998_P-wave AVAZ for inclined parallel fractures.pdf
    149.96 KB, 下载次数: 14
    2000_Fracture detection in Manderson Field A 3-D AVAZ case history.pdf
    1.9 MB, 下载次数: 10
    2000_Fracture Detection in the Manderson Field A 3D AVAZ Case History.pdf
    777.8 KB, 下载次数: 8
    2002,the leading eage,Recent advances in determination of fracture strike and c.pdf
    1.82 MB, 下载次数: 10
    2003hall_kendall_geophysics03Fracture characterization at Valhall_ Application o.pdf
    558.74 KB, 下载次数: 10
    2006_geophysics_WILLIS-Spatial orientation and distribution of reservoir fractur.pdf
    2.11 MB, 下载次数: 12
    2006-AVAZ parameter uncertainty estimation.pdf
    1.11 MB, 下载次数: 12
    2007_VVAZ vs. AVAZ practical implementation and comparison of two fracture detec.pdf
    1.31 MB, 下载次数: 13
    2008_A synthetic study to investigate the 3D structural effects on AVAZ analyses.pdf
    572.34 KB, 下载次数: 11
    2009_Automatic Anisotropic Velocity Analysis for Full Azimuth Gathers using AVAZ.pdf
    536.89 KB, 下载次数: 10
    2009_Non linear Bayesian inversion of seismic AVAZ and production data with resp.pdf
    884.07 KB, 下载次数: 12
    2010_The effect of interpolation on imaging and azimuthal AVO A Nordegg case study.pdf
    736.91 KB, 下载次数: 12
    2011_Azimuthal AVO analysis stabilizing the model parameters.pdf
    2.42 MB, 下载次数: 5
    2012_Anisotropy estimation for a simulated fractured medium using AVAZ inversion.pdf
    452.75 KB, 下载次数: 5
    2012_AVAZ inversion for elastic parameter and fracture fluid factor.pdf
    649.05 KB, 下载次数: 7
    2013_75thEAGE_Formation evaluation and rock physics analysis for shale gas reser.pdf
    4.55 MB, 下载次数: 9
    2013_AVAZ inversion and stress evaluation in heterogeneous medium.pdf
    784.52 KB, 下载次数: 7
    2013_Extracting azimuthal information from 3D full azimuth gathers using automat.pdf
    1.35 MB, 下载次数: 5
    2013_Fracture orientation and intensity from AVAz inversion A physical modeling study.pdf
    796.66 KB, 下载次数: 7
    2013_P-wave anisotropic attenuation attribute a potential tool to predict meso-s.pdf
    967.24 KB, 下载次数: 7
    2013_Unconventional gas detection by AVAZ and elastic inversion.pdf
    897.77 KB, 下载次数: 6
    2013-AVAZ inversion for fluid factor based on fractured anisotropic rock physics.pdf
    911.45 KB, 下载次数: 5
    2014_A case study of prestack orthotropic AVAz inversion for fracture characteri.pdf
    1.05 MB, 下载次数: 5
    2014_Anisotropy prediction and fluid discrimination using fractured carbonate.pdf
    719.54 KB, 下载次数: 7
    2014_AVAZ and VVAZ practical analysis for estimating HTI anisotropic properties.pdf
    538.54 KB, 下载次数: 6
    2014_Linearized orthorhombic AVAZ inversion Theoretical and practical consideration.pdf
    812.31 KB, 下载次数: 6
    2014_Seismic reservoir characterization for unconventional reservoirs using orth.pdf
    962.56 KB, 下载次数: 6
    2014-AVAZ inversion for fracture weaknesses parameters.pdf
    922.49 KB, 下载次数: 8
    2015_AVAZ interpretation using anisotropic rock physics.pdf
    1.21 MB, 下载次数: 6
    2015_Inversion of fracture properties based on frequency dependent seismic AVAZ .pdf
    549.54 KB, 下载次数: 7
    2015_Uncertainty and nonuniqueness in linearized AVAZ.pdf
    1.04 MB, 下载次数: 6
    2015-Correcting for VVAz prior to AVAz analysis.pdf
    961.39 KB, 下载次数: 6
    2015Geophysical Prospecting_An efficient wave extrapolation method for anisotrop.pdf
    1.55 MB, 下载次数: 6
    Seismic characterization of naturally fractured reservoirs using amplitude versu.pdf
    2.4 MB, 下载次数: 7
    Vilhelm_et_al-2010-Geophysical_Prospecting_Influence of crack distribution of ro.pdf
    722.35 KB, 下载次数: 6
  • 签到天数: 2526 天
    发表于 2017-4-24 07:44:31 | 显示全部楼层
    谢谢楼主
  • 签到天数: 1026 天
    发表于 2017-4-25 13:42:38 | 显示全部楼层
    谢谢楼主
  • 签到天数: 773 天
    发表于 2017-4-27 23:58:09 | 显示全部楼层
    楼主精彩
    GMT+8, 2025-7-26 08:01 , Processed in 0.058375 second(s), 22 queries .
