查看: 3715|回复: 0
[ECLIPSE] ecl中重启文件求教
  • 签到天数: 229 天
    发表于 2017-3-24 23:29:48 | 显示全部楼层 |阅读模式
    10阳光币
               1  Reading MULTIN
               2  Reading LOAD
               3  Reading SCHEDULE
    @--Problem
    @ Unable to open save file INJ.DATA.V0020
    @ Error code is : -1
    @--Error
    @ Unable to find step 20
    @ in SAVE file. Cannot perform the LOAD operation.
                0 Mbytes of storage required
      No active cells found
               14 Mbytes (image size)
    运行的e300模型,这是输出的PRT文件,求教各位大神该怎么改正?
    GMT+8, 2026-7-5 12:45 , Processed in 0.051749 second(s), 23 queries .
