查看: 918|回复: 0
[基本理论] linux的显卡好像不能用了
  • 签到天数: 52 天
    发表于 2016-8-31 09:00:09 | 显示全部楼层 |阅读模式
    我的蓝马启动不了三维可视化,查看了一下显卡,出现如下提示,是显卡驱动的原因吗?
    [root@bogon lmadmin]# lspci -vnn|grep VGA -A 12
    0f:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT200GL [NVIDIA Quadro FX 3800] [10de:05ff] (rev a1) (prog-if 00 [VGA controller])
            Subsystem: NVIDIA Corporation Device [10de:0661]
            Flags: bus master, fast devsel, latency 0, IRQ 74
            Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
            Memory at e0000000 (64-bit, prefetchable) [size=256M]
            Memory at f4000000 (64-bit, non-prefetchable) [size=32M]
            I/O ports at e000 [size=128]
            Expansion ROM at <unassigned> [disabled]
            Capabilities: [60] Power Management version 3
            Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
            Capabilities: [78] Express Endpoint, MSI 00
            Capabilities: [100] Virtual Channel
            Capabilities: [128] Power Budgeting <?>
    [root@bogon lmadmin]# lspci | grep -i vga
    0f:00.0 VGA compatible controller: NVIDIA Corporation GT200GL [NVIDIA Quadro FX 3800] (rev a1)
    [root@bogon lmadmin]# nvidia-smi
    Gpus found in probe:
    Found Gpuid 0xf000
    Attaching all probed Gpus...NVIDIA: could not open the device file /dev/nvidia0 (Input/output error).
    Failed to attach gpu
    Could not allocate resources!
    GMT+8, 2025-5-9 15:16 , Processed in 0.062342 second(s), 24 queries .
