查看: 3495|回复: 15
[其他软件] Open Porous Media (OPM) RELEASE 2016.04
  • 签到天数: 27 天
    发表于 2016-5-4 16:24:33 | 显示全部楼层 |阅读模式
    Open Porous Media 是由挪威SINTEF,Staoil,IRIS等单位一起合作开发的开源数值油藏软件,面向于工业油藏模拟应用,目前已经在某些石油公司内部使用,用以降低高额的油藏软件开支。 OPM采用与Eclipse兼容的输入,同时在一些现实的油藏模型与Eclipse的结果相匹配。最近他们发布了最新的2016.04版本。
    该软件的主页是 http://opm-project.org/
    该软件适合没有Eclipse软件的油藏工程人员以及尝试自己的新模型新算法的研究人员使用。Eclipse虽然功能很多,但是算法一般都是使用相对经典的算法。如果自己有新的模型,可以尝试利用OPM进行编程实现和测试。
    We are pleased to announce the availability of OPM release 2016.04. This is the first release this year, the previous release was 2015.10. The next release is expected to be 2016.10. Some features of the release include:
    • Further improved general performance for Flow, the fully implicit black-oil reservoir simulator.
    • Improvements to the extended versions of Flow: Flow-solvent handles more solvent effects and Flow-polymer has better performance.
    • Many of the upscaling programs have been cleaned up, and a few bugs have been fixed related to unit handling. Gravity is better handled in the relative permeability upscaling.
    • Major reorganization of modules, for more information see the updated modules page.
    We’d like to thank all who played a part in the release, for finding bugs, posting issues, writing code, reviewing, testing and packaging.
    Instructions for installation are found on our download page. Binary packages are available for Ubuntu and Red Hat Enterprise Linux, instructions are available for building from source for any Linux variant or Mac OS X.
  • 签到天数: 27 天
     楼主| 发表于 2016-5-5 20:11:58 | 显示全部楼层
    up. 这个论坛的回复才可以看什么东西的功能也许在什么方面还不错,但是的确不容易有好的讨论啊。 太多的看一看5个字什么的哈。。:D
  • 签到天数: 12 天
    发表于 2016-5-6 00:46:22 | 显示全部楼层
    好东西,学习
  • 签到天数: 27 天
     楼主| 发表于 2016-5-7 17:34:05 | 显示全部楼层
    欢迎多交流。 如有碰到任何问题,可以咨询。
  • 签到天数: 1492 天
    发表于 2016-5-9 13:21:44 | 显示全部楼层
    请问楼主,之前你的帖子中介绍了mrst,这两款软件(或插件)有什么区别吗?一般都能做什么工作呢?
  • 签到天数: 17 天
    发表于 2016-5-10 00:17:16 | 显示全部楼层
    请问楼主我照着opm网站安装,但是后来就安装不上了,是不是安装教程和现在的不兼容呢
  • 签到天数: 27 天
     楼主| 发表于 2016-5-10 03:29:36 | 显示全部楼层
    http://opm-project.org/?page_id=36上的安装教程应该是新的。你说的装不上了是指?你用的什么系统呢?
  • 签到天数: 27 天
     楼主| 发表于 2016-5-10 03:41:58 | 显示全部楼层
    MRST和OPM算是孪生兄弟。两个软件都支持角点网格,都支持Eclipse格式的Deck输入,都可以做黑油和polymer等的模拟。MRST逐渐会有组分流的模拟。
    MRST面向的是快速原型开发和研究。由于MATLAB语言的特点,开发相对迅速。所以在OPM上非常大的功能都是在MRST上研究测试过的。然后Eclipse很多的算法和格式比较过时,MRST很多采用的更新的算法,所以在有些情形下,MRST和Eclipse的结果不一定是匹配的。基于MRST发表的文章比OPM的多太多。
    OPM是面向工业应用,基于C++开发,对性能的要求比较高一些。由于工业石油公司伙伴的需要,OPM的开发要求匹配Eclipse的结果,开发的成分更多,研究的成分更少一些,导致目前一直文章不多。目前主要有黑油,Polymer和Solvent几个方面的功能。现在OPM已经进入工业试用阶段,在匹配Eclipse结果方面做得比较好。 后面不一定会一直拘泥于Eclipse已有的功能,可能会有不同的研究性质的新算法和新模型出现。如果C++编程不错,OPM也是不错的研究平台。
  • 签到天数: 1492 天
    发表于 2016-5-10 11:40:30 | 显示全部楼层
    Paean 发表于 2016-5-10 03:41
    MRST和OPM算是孪生兄弟。两个软件都支持角点网格,都支持Eclipse格式的Deck输入,都可以做黑油和polymer ...
    非常感谢!!!解答的非常详细!
    虽然个人编程基础比较差,但是还是非常有兴趣!!!
    希望楼主多多发布一些相关的信息,相信有不少人会持续关注的
  • 签到天数: 17 天
    发表于 2016-5-12 15:46:02 | 显示全部楼层
    谢谢楼主回复,当时出现问题界面关掉了,没有详细介绍。这次我基于已经在windows系统安装好的虚拟机系统里重新下载安装opm,照着my first reservoir model的教程做,做到输入 flow  SPECASE1.DATA,系统提示error while loading shared libraries:libopmcore.so.2015 can not open shared object file:no such file of directory。我先update,然后输入cd libopmcore.so.2015,还是显示no file or directory。我对编程还不是很熟悉,一头雾水,非常感谢楼主解答。
    GMT+8, 2025-5-12 18:45 , Processed in 0.052990 second(s), 20 queries .
