查看: 1274|回复: 1
[基本理论] 建模理论
  • 签到天数: 15 天
    发表于 2016-2-25 23:28:45 | 显示全部楼层 |阅读模式
    定义地质步骤参数包,
    写一个类集成described arguments by reflection
    创建一个property和field to save the input and output arguments.
    譬如well log和pillar gird 是输入参数
    property和cell count是输出参数
    Petrel allows using variables in the workflow editor. Two types of variables can be
    defined:
    Object Variables refer to the objects in Petrel and are also called reference
    variables.
    These are predefined in Petrel and can be found under the Variables
    folder of the Workflows pane.
    Under Variable folder, there is a special variable
    called "Output" when used;
    it contains the result from the latest executed process
    in the workflow.
    For example, after a Volume calculation workstep, the Output
    variable will hold the information about the name of the Volume run.
    Variables are defined by a numerical value or a string. It is defined using a “$”
    sign preceding it (for example $pi = 3.14).
    Any variable must be defined in the workflow before it is used.
    Refer to Petrel Help for details on the usage of workflow variables in Petrel.
    Processes may be purely interactive, purely algorithmic, or a combination of the two.
    An interactive process might require the user to select data on the screen or manipulate
    data in space, such as creating a point set from a series of mouse clicks.
    An algorithmic process requires the user to enter some inputs and maybe outputs and then run a
    computation, such as creating a borehole with a well trajectory from an existing point
    set.
    An algorithmic process requires the user to set up the inputs and outputs before it is
    run. This means the UI typically has data entry fields, Petrel blue arrows, etc. Typically
    the process would invoke a workstep to actually run the algorithmic step.
    An interactive process has the user give input data by manually interacting with data in
    a window (typically with mouse clicks). This means the UI does not take input; it just
    explains how to run the process interactively
    public class Arguments:DescribedArgumentsByReflection
    //input arguments
    public int numCells{get;set;}
    private Welllog m_welllog;
    public Welllog Mwelllog
    get{return m_welllog;}
    set{}
    public class Arguments: DescribedArgumentsByReflection
    //input parameters
    private WellLog m_welllog
    public WellLog InputWellLog
    set {welllog=value;}
    internal get{ return welllog; }
    private Grid InputGrid
    set{gird=value;}
    internal get{return gird;}
    private slb.ocean.petrel.domainobject.property prop
    get{return prop;}
    internal set{ prop=value; }
    You need to tell the system what roles the arguments have: whether they are input
    arguments, output arguments, or both. This is accomplished via the accessibility of the
    property get and set.
    For an input argument, the system will need to give the argument value from the UI.
    The set is public to allow the system to load the argument value from the UI into the
    argument package.
    The get for an input argument does not need to be public
    because the system does not need to use it, so you make it internal by convention.
    The accessibility is reversed for an output parameter.
    The set that you use to export
    the results is internal;
    the get used by the system to retrieve the argument values
    from the workstep is public.
    private Grid m_grid;
    //output arguments
    private Property m_outProp;
    public
    custom upscaling argument package
    well log input, pillar grid input, pillar grid property output, property cell count output
    argument package
    describedargumentsbyrefelction
    A line UI within the petrel workflow editor
    a default table based dialog ui
    interoperability with the petrel workflow editor automatic support for workflow variables in the line UI
  • 签到天数: 508 天
    发表于 2016-2-26 08:39:48 | 显示全部楼层
    钦佩会编程的人
    GMT+8, 2025-4-25 03:57 , Processed in 0.049953 second(s), 20 queries .
