查看: 4251|回复: 4
[Landmark] landmark openworks R5000安装问题
发表于 2016-2-22 10:46:08 | 显示全部楼层 |阅读模式
最近在安装landmark openworks R5000,环境是RHEL5.7,用Geforce9500GT显卡..
安装完后发现数据库可以启动,但运行startow后,界面显示不正常,command menu显示不出文字,只是白色方框..也没报什么错
据说Openworks需要Quadro显卡.请问各位前辈,我的问题出在那里如何解决,是否是显卡问题,openworks可以用Geforce显示卡吗,如果非要用Quadro显卡..
有什么办法可以用geforce显开替代吗.谢谢!如果可以用Geforce显卡..具体用什么型号..据说用软件可以模拟Quadro显卡?,在vmware虚拟机上安装?
 楼主| 发表于 2016-2-23 09:28:41 | 显示全部楼层
运行startow后,错误如下:
src/cpp/LGCbase/wid/wut/wutConverter.c:126                0  wutInstallCmapTypeConverter: Colormap Completed Successfully
src/cpp/LGCbase/wid/wut/wutConverter.c:131                0  wutInstallCmapTypeConverter: Visual Completed Successfully
src/cpp/LGCbase/wid/wut/wutConverter.c:136                0  wutInstallCmapTypeConverter: Depth Completed Successfully
Warning: Color name "Green " is not defined
src/cpp/LGCbase/ns/nsRecv.c:94        300000008  nsRecv: received EOF: closing conn
src/cpp/LGCbase/ns/nsPdEx.c:79        300000008  PdExCmd: nsRecv() failed
  • 签到天数: 22 天
    发表于 2016-2-24 10:24:53 | 显示全部楼层
    重新建个蓝马用户试试,可能建用户的过程有问题。
     楼主| 发表于 2016-2-24 11:35:56 | 显示全部楼层
    从错误内容分析,象是lgcuser部分出现网络连接错误..如下图所示..命令栏中无任何显示..
    配了新用户..还是出错..很费解..
    # NetD server configuration file
    # This file is read when NetD starts up or restarts. It is used by
    # NetD to construct a table of socket/tli based services that it can service
    # requests. See inetd.conf(5) for syntax. In addtion, sock_type has been
    # changed to serv_type with the additions of "cots" and "clts" for streams
    # based servers (i.e. SVR4). Also, SVR4 uses  TIRPC which does not
    # require the protocol to be specified. As a result, "rpc/ti" can be used.
    # LOG:
    # 10/29/93  DMA Version 1.03 and greater limits the daemon locations to
    #               OWHOME/bin so that NetD is auto-configurable
    # 11/09/94  DMA Upgraded to new NetD release 1.1.0
    # 10/25/95  DMA Added PD Executor daemon
    # 10/27/95  DMA Added exclusive wait support to NetD (waitex)
    # General syntax:
    #<service_name> <serv_type> <proto> <flags> <user> <servername> <args>
    lgc_rex         stream      tcp      nowait root    RSvD
    netd_ping       stream      tcp      wait   root    NetD_Int
    pdex            stream      tcp      nowait root    PdEx        -autoexit
    pdex_lock       stream      tcp      waitex root    PdEx
     楼主| 发表于 2016-2-25 11:19:42 | 显示全部楼层
    GMT+8, 2025-5-14 00:27 , Processed in 0.053224 second(s), 27 queries .
