查看: 1843|回复: 1
[技术讨论] Discovery of by-passed oil zone consisting of rubble split by fracture network
    发表于 2015-11-18 23:59:39 | 显示全部楼层 |阅读模式
    Discovery of by-passed oil zone consisting of rubble split by fracture network in tight reservoir
    QI Cheng-wei
    Chongqing University of Science and Technology,   Shapingba District of Chongqing  401331
    Abstract: Compared with natural gas flowing in porous media, oil flowing in porous media does not have pressure difference resulted from volumetric expansion between interior and surfaces of rubble. Meanwhile numerical value of pressure difference is very small between upstream ‘stagnation point’ and downstream ‘stagnation point’ produced by oil or gas flowing around rubble. Thus oil flowing in pores of rubble nearly stop because of extremely small pressure gradient. Similar analysis shows that oil can hardly flow in pores in most space of narrow peninsula-like parts or those with ‘necks’. Therefore, the fracture network zone becomes a by-passed oil zone, and the recovery efficiency is inversely proportional to the coverage of the fracture network. Hence, successful ‘3D-Shattered Fracturing (3DSF)’ in shale gas reservoir can’t be applied to develop tight oil reservoir. It’s suggested that researchers should try to find more proper methods to improve single well productivity without reducing recovery efficiency.
    KeywordsMechanics of fluids in porous media; Kinematics of fluids in porous media; Shale gas reservoir; 3D-Shattered Fracturing; Recovery efficiency; Equation of state; Principle of minimum energy; By-passed oil zone
    weixin : y_ou_r               QQ : 1261621
     楼主| 发表于 2015-11-21 23:09:29 | 显示全部楼层
    QI Cheng-wei
    Key wordsMechanics of fluids in porous media; Kinematics of fluids in porous media; Shale gas reservoir; 3D-Shattered Fracturing; Recovery efficiency; Equation of state; Principle of minimum energy; By-passed oil zone
    GMT+8, 2026-6-16 10:19 , Processed in 0.045529 second(s), 24 queries .
