查看: 810|回复: 0
BERO™ for OakLand Oil, Mynra 1 Lease
  • 签到天数: 31 天
    发表于 2015-9-17 22:46:57 | 显示全部楼层 |阅读模式
    BERO™ its a polymerized bio-BERO™ product, and its water soluble. It has a very strong ability in releasing the hydrocarbon on the surface of reservoir rock particles. After being injected into the formation, it could adhere to the surface of formation for a long time due to its activity and turn the property of rock formation into hydrophilic biological surface, which could reduce the interfacial tension of wetting angle and reservoir rock particles and thereby decline the flow resistance of crude oil in the reservoir pore. Meanwhile, as the bio-degradation function of BERO™will constantly cause oil drop to deform and split, and be released from the rock formation,  not only the crude oil in stagnant layer would be loosened but the oil drop would also be made to become **aller and much easier to be effused independently from the micropore till recovery. A kind of moderate emulsion comprising of oil, water, organi**s, etc will be formed due to the characteristic of BERO™. This emulsion has the function of resistance, touching and changing to the stagnant layer, and thereby achieves the effect of cleaning, displacement of reservoir oil and injection reduction, and enhanced oil recovery. At the same time, the problem of pore blockage and secondary pollution will not appear as it will not produce any other new products.
    OakLand Oil, Mynra 1 Leasen BERO.doc
    1.77 MB, 下载次数: 1
    GMT+8, 2025-5-9 15:15 , Processed in 0.052997 second(s), 22 queries .
