查看: 2561|回复: 4
[其他] 石油钻井业常用专业词汇
发表于 2008-12-11 10:33:30 | 显示全部楼层 |阅读模式
参数优选 || parametric optimization
残酸 || reacted acid
残余饱和度 || residual staturation
残渣 || gel residue , solid residue
测量 || measure
侧链 || side chain
侧钻水平井 || sidetrack horizontal well
层间 || interlayer
层间距 || the distance between the two crystal layer, layer distance
层理 || bedding
层流 || layer flow
差减法 || minusing
尝试 || trial
柴油 || diesel oil
长连缔合物 || long chain associated matter
操作方法 || operation method
超伸井 || high deep well
超深预探井 || ultradeep prospecting well
超声波 || ultrasonography
超高密度泥浆 || extremely high density mud
超细碳酸钙 || super-fine calcium carbonate
产层 || production/pay zone
产层亏空 || reservoir voidage
产量 || production ,output
沉淀 || precipitation
沉降 || subside
沉降速度 || settling rate
沉砂 || sand setting
衬套 || sleeve
程序 || program
成对水平井 || paired parallel horizontal wells
成分 || ingredient
成胶剂 || gelatinizing agent
成膜树脂 || film-forming resin
成岩性差 || poor diagenetic grade
承压 || bearing pressure
承压低 || lower pressure resistance
承压能力 || loading capacity
尺寸 || dimension
斥力 || repulsion
除硫效果 || sulfur limitation effect
除硫剂 || sulfur elimination
除砂器 || desander
触变性 || thixotropy
触变剂 || thixotropic agent
垂沉 || sag
垂直井 || vertical well
充气钻井液 || aerated drilling fluid
磁化 || magnetization
次生有机阳离子聚合物 || secondary organic cationic polymer
冲砂 || sand removal
冲蚀 || flush
冲刷 || washing out
冲洗 || clean
冲洗效率 || cleaning efficiency
冲洗液 || washing fluid
从…角度 || from the standpoint of
丛式井 || cluster well
稠化剂 || gelling agent
稠油区 || viscous oil area
稠油藏 || high oil reservoir
初步分析 || preliminary analysis
初始稠度 || initial consistency
初始粘度 || initial viscosity
初探 || primary investigation
处理剂 || additive ,treating-agent
粗分散泥浆 || coarse dispersed mud
粗泡沫堵漏工艺 || coarse-foam plugging technology
促凝剂 || accelerating agent
醋酸 || acetate
醋酸钠 || sodium acetate
窜流 || fluid channeling
脆裂 || embrittlement crack
脆性 || brittle/crisp ,fragility
催化剂 || accelerant , catalyst
萃取剂 || extracting agent
参与人数 1贡献 +1 收起 理由
pandianyou + 1 建议去别的版块发。这里石油地质
  • 签到天数: 209 天
    发表于 2008-12-16 20:24:48 | 显示全部楼层
    谢谢提供词汇
    发表于 2008-12-19 11:18:10 | 显示全部楼层
    能够有词汇解释对我们这些初学者就更好了
    发表于 2008-12-29 21:49:52 | 显示全部楼层
    呵呵呵,欢迎再发多些。
    发表于 2009-5-17 15:27:46 | 显示全部楼层
    很好的资料,谢谢
    GMT+8, 2025-5-14 06:37 , Processed in 0.049100 second(s), 23 queries .
